The best LTR Camshaft?
Old Sep 25, 2001 | 03:58 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Accel Base Manifold, AS&M Runners, Ported plenum, pocket ported Dart 180 heads on a 350. If anyone has a similar set-up, and you have track times (trap speeds), what's the best cam (hydraulic roller retrofit)for the application? The cams I am considering are listed below:
zz-9:
212 226
.483 .520
Lingenfelter:
74211
211/219 .499"/.525"
74216 213/219 .462"/.471''
74219 219/219 .525"/.525"
SLP Camshaft Specs: Valve Lift Duration@.050
51004
in: .495'' 218
ex: .502" 224
51008
.502'' 224
.510'' 230
Old Sep 28, 2001 | 07:45 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Not one Response? Nobody has Any of the above camshafts? It's gonna cosy about $1000 bucks to retro-fit a cam, and I don't want to walk into it blind, so if you have one of these cams, please reply with a list of mods and 1/4 mile times.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Sep 28, 2001 | 09:34 AM
Mike89GTA's Avatar
I would post some times but I haven't finished putting mine together yet. I'm using the LT4 Hot Cam. I hope it works well.
89 GTA 4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085,
LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers,
SLP Cold Air Intake, Crane AFPR, 48mm TB, SuperRam base manifold
(ported), ported plenum, stock runners (not for long) , 95Z #24
injectors, stock fuel rails..
BTT
[This message has been edited by Mike89GTA (edited September 28, 2001).]
Old Sep 28, 2001 | 11:07 AM
GTA383's Avatar
I have a Comp roller that is nearly identical to the SLP cam you listed.
in: 218/495
ex: 224/503
It was a retrofit cam and I believe it was about $50 cheaper than the SLP.
Anyway, just got the car running after rebuild so I dont have any times yet.
Old Sep 28, 2001 | 11:11 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
<font face="Verdana, Arial" size="2">Originally posted by GTA383:
[B]I have a Comp roller that is nearly identical to the SLP cam you listed.
in: 218/495
ex: 224/503
B]</font>
I went with the same cam. I have the same setup but I went with TF Heads.
Old Sep 28, 2001 | 11:59 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I prefer the LPE 74219 cam.
219/219 .503/.525 112lsa.
Great Midrange and Top End!
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Oct 7, 2001 | 03:13 AM
FORMULAno87's Avatar
not one of these cams do i own.
but i would like to....
daily beaten 87 formula
87 Monte SS project car
Old Oct 7, 2001 | 05:09 AM
Ski89Z28's Avatar
Ok, I have a 89n IROC 350 with the ZZ9 cam with 6085 Edelbrock heads, TES headers, 1.5 RR, 2000 stall convertor,MSD 6AL, ported plenum, underdrive pullies, TPIS level V chip and a custom dual exhaust. I have a stock UNPORTED intake manifold, stock runners and a stock suspension with 2.77 gears.
The stall convertor is too low it should be at least a 2500 more like 2800. I say this cause the cam turns on at around 2800 - 3000 rpms definately can fell it!
I've had vacuum problems and been fixing them since the cam install. With these vacuum problems I ran a 14.12 @ 96.99.
I fixed the vacuum problems but didn't reset the idle to 750 rpms (don't ask) and ran it 2 times at the track.
First run was a 13.94 @ 98.5 (I think on the mph).
Second run was a 13.87 @ 98.99 (same as in sig).
I think I can get it down to a low 13.7X or even a 13.69 but I'm not going to the track till next year. Now on these runs all I did was get to the line and let it idle and hit the gas, no stalling it to a certain rpm. Also on the first run I let the auto do all the shifting but on the second run I left it in 2nd and let it shift from 1st to 2nd and I shifted to 3rd at 5400rpms. And yes it still pulls at 5400rpms.
I think the the tranny shifts at 5100rpms and going aliitle high helped but I got to go back and see and it isn't happening this year.
I drive it daily unfortnately but we do what we can. I have no problems on emissions.
Did this help you? I hope.
Good Luck.
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Old Oct 7, 2001 | 09:30 AM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I don't have any of those cams, but I'm using the ZZ4 cam(similar to the ZZ9 with less duration). With the mods in my sig and the stock chip, I've ran a best of 13.2@105.5 on street tires with a 2.02 60'. My car needs a bigger cam and a custom chip(I've just started burning my own).
Sparks a flyin'
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
Old Oct 7, 2001 | 11:44 AM
Todd85's Avatar
I used to run the LPE 74211 with my 350 motor. With dart heads, Accel large runners, Accel base, 52 mm tb, ported plenum, headers and a 2500 rpm converter at a raceweight of 3500 lbs, I ran 1.70 60 ft, 12.42 @ 109 mph. With a lightweight friend driving it hit 110 mph. (3400 lb raceweight)... I don't think a 350 Long runnered motor has much more than that in it.
good luck
Todd
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
