87 Formula for Drag Car?
Old Oct 5, 2001 | 08:59 PM
ZPI28's Avatar
Engine: 5.7L L98 TPI
Transmission: Automatic
I found an 87 Formula Firebird for $75. No motor,trans,dash,seats,hood,or front clip. It is basically a rolling chassis. Would this make a good dragcar? It is a hardtop if I get it I will drop in my 406ci out of my Nova(7.68 1/8th)Would like for this to be a 7sec 1/8th mile car. Any recommendations?? This car came with a LB9,going to see if it has the G92 option.
91 Z28 305 TPI
single 3"flowmaster
ported plenum,siemesed runners,
gutted airbox,
160 robertshaw thermo
273 gears,auto
9.47 1/8th mile
on goodyear eagles
Old Oct 5, 2001 | 09:07 PM
92RSB4C's Avatar
Me & you thing exactly the same. Check out the article I posted on my 86 Z28 here: https://www.thirdgen.org/messgboard/...ML/003559.html and my 86 Z28 here: https://www.thirdgen.org/rides/index...ew&rideid=6180 . Also check out my home page at: 92rsb4c.mychevyworld.net
BOMB BIN LADEN I see dead Afghans in dead Fords on the side of the desert path.
Old Oct 5, 2001 | 11:20 PM
92RSB4C's Avatar
I think with some roll bars and some sub-frame connectors, it would be a good racer. You'd have to put some cover plates on the heater core holes to make it a "firewall". Also, if you put a fuel cell in the "trunk" area, you'll need to make a firewall back there too. As far as I know, you'll also need a battery cut-off switch if you put the battery in the "trunk". I would make some plexiglas windows except for the rear b/c it is hard to form a plexiglas duplicate, plus the weight over the rear wheels helps. The frame of a camaro is pretty light, when it is "naked", I could pick it up off the jacks! Maybe I'll race you one day. Good luck!
Old Oct 6, 2001 | 01:37 AM
ZPI28's Avatar
Great looking RS looks alot like my Z.
MY Z28
Maybe we will race someday. I will most likely box in the rear and add a 4-link. This is going to be a project for a couple of years. Thanks
91 Z28 305 TPI
single 3"flowmaster
gutted airbox,
273 gears,auto
9.47 1/8th mile
on goodyear eagles
Old Oct 6, 2001 | 09:22 AM
92RSB4C's Avatar
Your link didn't work. There's 2 http's and after you take one off, the site still doesn't go thru.
Old Oct 6, 2001 | 10:40 PM
ZPI28's Avatar
alright try www.skeeter.cz28.com
copy and paste this and you can get there.
Old Oct 6, 2001 | 11:51 PM
Momar's Avatar
That link still doesnt work. I even tried to type it in and it still doesnt work. Are you sure you put in the right address?
Old Oct 7, 2001 | 08:08 PM
92RSB4C's Avatar
Your Z28 nearly looks like my RS. BTW, the link workrd for me.
Jorlain
Aug 24, 2022 05:11 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
