cold air setup question
Old Oct 11, 2001 | 12:07 PM
ssbowtie1's Avatar
Hi everyone, I have a 88 Camaro IROC. I have two K&N filters installed. IS the big black air induction setup right before the MAF restrictive? Are there any options for a cold air setup that would actually flow better. Is it worth doing it and does it actually improve airflow and power? Thanks everyone for your help.
Old Oct 11, 2001 | 04:47 PM
The AntiModerator's Avatar
That factory set-up is pretty good. It becomes even better when you remove the box that hold the filters and punch holes through the draw air from in front of the radiator. Try this:
https://www.thirdgen.org/newdesign/tech/ramair.shtml
Old Oct 11, 2001 | 08:39 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
just send the car to a junkyard.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
completely done over suspension, black paint with flames,
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
Old Oct 12, 2001 | 07:08 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I did the ram air mod, works great.
Louis
Convertable
92 Z28 305tpi Auto
1/4 at 12.99 @ 109.07mph w/Paxton 10psi, Ram air mod,Water methanol inj.,52mm T/B,ASM Large tube runners, ported upper & lower intakes,AFPR,23# injectors,1.6 roller rockers,slp tri-y headers,3in. cat,3in. gale banks cat back system,3.42 gears,17x9 camaro SS wheels, 285x40x17 tires,and much more.
http://www.lbsz28blown.cz28.com
Terrell351
Jun 13, 2021 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
