Built Cold Air Intake PIX
Old Oct 6, 2001 | 08:38 PM
mtccl's Avatar
<img src=www.angelfire.com/ma4/transam/intake.jpg>
I used the examples posted on this message board to build this intake. Thanks guys!
www.angelfire.com/ma4/transam/index.html
1987 Trans Am, 305 TPI, K&N, Cherry Bomb Muffler
"35 yr old helo pilot with a cool new toy my 17 yr old son wants"
Old Oct 6, 2001 | 08:43 PM
mtccl's Avatar
<img src=http://www.angelfire.com/ma4/transam/intake.jpg> </a>
Sorry I hope this picture works. If not go to my webpage to see.
Old Oct 6, 2001 | 09:32 PM
92RSB4C's Avatar
That's pretty cool. I was just wondering, what are the advantages of a cold air induction over the "Y" induction(the one that goes over the radiator)?
BOMB BIN LADEN I see dead Afghans in dead Fords on the side of the desert path.
Old Oct 6, 2001 | 09:54 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
firebirds can't do the y deal because they have no foglight holes to draw air from. there is really not much of a difference in that they both get "cold" air but the y deal is a little restrictive. but you can make ram air kits for the y deal
Andrew
Old Oct 6, 2001 | 10:10 PM
92RSB4C's Avatar
Just a thought, if you block off the foglight holes for a ram air, how would the radiator cool off?
Old Oct 6, 2001 | 10:55 PM
88IROCs's Avatar
The foglight openings don't supply cold air to the rad, that's done by the little spoiler under the chin. The foglight openings do supply cold air to the oil cooler, so I wouldn't block them off completely.
If you're still using the stock factory 2-into-1 snorkel, you really don't need much of a scoop. The stock snorkel is so narrow and restrictive after the filters, that a scoop isn't going to increase airflow all that much, but it should allow colder air in.
Old Oct 7, 2001 | 12:07 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Looks great. Hope my posts helped you some. If anybody else wants to see how it's done, I've got the tech on a new page.
http://87tagta.tripod.com
Just scroll down the frame and goto CAI.
Old Oct 8, 2001 | 04:17 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
how restrictive is the Y thing? i have seen some pretty fast cars runin with it
86 IROC
43,000 miles
305/700R4/3.23 gears
maroon, gold stickers, black interior, T-Tops.
current mods.
shift kit
headers
cat back exhaust
mods planned for this winter
cam
3.73 gears
subframe connecters
Old Oct 8, 2001 | 05:24 PM
88IROCs's Avatar
Guess it depends on what you consider fast?
Right after the air gets past the filter, it must make a right-turn and try to squeeze through an opening of only 15/16"(by 7"). It follows that path, but just before turn into the y-proper, the height of the tube necks down to about 1/2"(internal). That means the total area(both legs of the y) is about 7 in. sq. So, in my mind, if you are forcing air through this intake: more than likely you are only increasing on the considerable turbulence that already exists. Obviously, the whole y-section was an afterthought by Chevy, as they had no way of knowing in the design stages that one day thirdgen Camaro's would have to take air that far forward of the engine(at that time -late 70's- all GM's breathed thru the top -whether carbureted, CFI, or Buick turbo).
Short of installing a shorter rad or making a cowl-induction hump that extends to the nose, both of which may compromise cooling, you're kind of stuck with this restrictive breathing scheme. Kind of explains why no aftermarket manufacturer has designed a cold-air induction that follows the factory path.
Old Oct 8, 2001 | 10:52 PM
mtccl's Avatar
Posted a more detailed explanation and more pix to the website.
The Phoenix Project..click to see my project car
Old Oct 10, 2001 | 06:30 PM
dcwldman's Avatar
Hi I have a 87 TA 5.0. TPI. With a 88 TA motor. Is the 88 motor an the same HP as the 87??
Thanks DEAN
<font face="Verdana, Arial" size="2">Originally posted by mtccl:
</font>
Old Oct 12, 2001 | 10:27 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
The cold air / ram air works best & car dose not get hot.
Check sig more pics at my site.
Louis
Convertable
92 Z28 305tpi Auto
1/4 at 12.99 @ 109.07mph w/Paxton 10psi, Ram air mod,Water methanol inj.,52mm T/B,ASM Large tube runners, ported upper & lower intakes,AFPR,23# injectors,1.6 roller rockers,slp tri-y headers,3in. cat,3in. gale banks cat back system,3.42 gears,17x9 camaro SS wheels, 285x40x17 tires,and much more.
http://www.lbsz28blown.cz28.com
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
