confused about spark plugs
Car: '89 trans am gta
Engine: 5.7 L 350 TPI
Axle/Gears: not a clue!
some work is being done on the car, and i thought this would be a good time to check out the spark plugs. the car had a tune up last year, but the shop put on some ford autolites. they work...but i was told by the mechanic who's working on it now that i may want to go to something different.
i've got an 89 gta 350 5.7L w/tpi. msd ignition, headers, hypertech chip, cold air, 3" exhaust...and some other stuff that may or may affect the engine much: new alternator, water pump, smog delete, & 180 thermo. (i'm sure there's more, but i can't think of them.)
the "inside" (cam, heads, etc) of the engine is stock.
what do you guys recommend for plugs? i've heard a lot of different stuff, but it contradicts itself: these are good, those suck, no wait..these are fine.
i'd like some real world help from the guys and gals that drive these cars.
thanks.
thanks.
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: confused about spark plugs
You can't go wrong with AC Delco. I have used them over the years and the price is great. Just don't get caught up in the gimics. Get the basic plug - gap it and run that thing.Rabi C.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
and its a 1983 crossfire 305
Never use rapidfires they are junk.
stick with your stock AC Delco sparkplug
Car: 92 Z-28
Transmission: THM700R4
Two reasons that you want to stick to the stock plug and not go platinum: 1. Cost. 3-4 x as much. 2. Your motor is not new and you may find that you will replace them between 20-30K miles anyway. Thread
