Pics of my TPI Swap
Old Oct 9, 2001 | 02:25 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Pics of my TPI Swap
Dirty, but that's New Mexico for ya...
http://www.monte-list.com/html/image...rty_tpi001.jpg
I do plan on mounting the battery sideways so I can mount the air filter forward.
http://www.monte-list.com/html/image...rty_tpi002.jpg
Shows the DS header (Hooker finally came up w/ a set of emissions legal ones for the G-body w/ L69 cat) I bought these from Jet-Hot.
jmd
1986 SS with...
86LB9 TPI atop the original L69, Hooker emissions legal PN 2050 headers, stock L69 cat (yes, a real one), hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
Old Oct 9, 2001 | 10:05 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Your prolly loosing some HP from the placement of your air cleaner..
-- Joe
1989 Formula 350 4-bolt
mains, Forged .030 TRW
pistons, SLP 51010
Roller Cam, World
Products Sportsman II
2.02/1.60 heads
Edelbrock TPI Intake
24lbs/hr Injectors
Cloyes Double Roller
timing chain, Comp Cams
roller lifters: 13.86 @
99.88 MPH
-- Joe
Old Oct 9, 2001 | 11:05 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
is the first pic the finished product?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
www.gcfba.com (Greater Cincinnati F-Body Association)
http://www.cincyspeed.com/
Old Oct 10, 2001 | 12:01 AM
jmd's Avatar
jmd
Yes, I know the air filter placement isn't optimum, but somehow I thought having the car running was more important than taking time to relocate the battery etc.
The first pic is basically the finished product with zero detailing. The ducting was borrowed off a car that sat for a long time, and my car sat for a bit too w/ out a hood on it.
J. Matthew Daugherty
1986 SS with...
Old Oct 12, 2001 | 11:17 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Unless you want to buy a new battery every few months, DO NOT MOUNT THE BATTERY SIDEWAYS. Batteries are mounted in this position to keep the plates in the cells from smacking together upon acceleration and deceleration. Mount your battery in the trunk for $40 bucks, I think Summit sells the kit, and for *** 's sake move your air intake.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Oct 13, 2001 | 04:11 PM
Jason M 91Z's Avatar
So what happens when you turn? Mount the battery any way it'll work, but you may have to fab some type of fixture to hold the battery and locate it on a tray.
-Jason M. 1991 Camaro Z28
[This message has been edited by Jason M 91Z (edited October 13, 2001).]
Old Oct 13, 2001 | 04:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I gotta learn to make them funny "rolling-eye" things....
Old Oct 13, 2001 | 09:14 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
nice swap man. too bad nobody else here gave you props for what looks like it could be a difficult install. im sure you'll work all the bugs out now you have a monte with what it SHOULD have come with from the factory. have fun with it and good luck.
Old Oct 13, 2001 | 10:28 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Don't vettes have the batters mounted sideways?
Anyway, I second the relocate kit. I'm going for that myself. I run a 700amp batt in my car, if my headers heat the starter up too much I can't restart. I'm thinking of two 650s in the trunk.
-- Joe
Old Oct 13, 2001 | 11:29 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
heres another idea, get a hawood hood and make an aircleaner that fits the cowl opening, I did it with mine and got to leave the batt where it is at, if I can get some pics developed for it Ill post them on here.
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. Found a guy who can build me a ford 9" (yep sorry guys) for less than 500 then comes all the goodies such as disk brakes so on and so on, will it ever end?? I hope not!!
Old Oct 14, 2001 | 01:26 PM
jmd's Avatar
jmd
<font face="Verdana, Arial" size="2">Originally posted by TPI Guy:
</font>
My car corners damn hard too and its' only gonna get better w/ front eibachs, guldstrand rear springs & maybe go to GW trailing arms. I had a good suggestoin though in email - one of those $$ gel cell batteries.
Or... move the batt to the DS w/ firebird parts
FWIW, it's running very cool (88 'bird alum. 5spd radiator, delco 180 deg. stat) and I have zero hot start problems. headers are Jet-Hot coated, FWIW.
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
nice swap man. too bad nobody else here gave you props for what looks like it could be a difficult install. im sure you'll work all the bugs out now you have a monte with what it SHOULD have come with from the factory. have fun with it and good luck. </font>
Thanks I did jump on the 86 LB9 stuff because I heard the (wrecked) iroc run and the runners weren't all dented etc. 86 to 86 was pretty straightforward; the Helms for Camaro has LG4 & LB9 diagrams right next to each other. Luckily, GM made 2 EFI g-bodies - 85-88 4.3L V6 TBI Monte's, and 84-87 Turbo Regals. I'm using a 4.3 Monte sending unit, but now I need the better baffled EFI tank (got one lined up )
anesthes - won't the longer batt. cable be an issue? Your starter still needs to not be cooked to get it started; I'm afraid you may be chasing the wrong culprit
monte-ss I have several friends w/ the Harwood hood (I attend the Monte Nationals in June) and I really don't want to mess w/ making 'glass fit right and all; plus I like the stock hood. Should hold up to the 100mph driving I do when I trip to Phx or Denver. Don't need the extra room either. Just remove the stupid rubber gasket at the rear of the cowl which helps and roll...
Matthew
1986 SS with...
Old Oct 14, 2001 | 08:31 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Several GM cars have the battery mounted sideways. Its not a big deal.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
1984HO
Mar 19, 2021 11:59 AM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
