Excessive valve train noise?
Old Oct 17, 2001 | 07:54 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
The passenger side valve train keeps making a loud clacking noise and I don't think its from loose rocker arms although it sounds like one is loose. Its loud enough to set off the knock sensor at certain loads and rpms, usually pretty light load.
Sounds like its the rear exhaust valve.
I don't think its the rocker arm adjustment being too lose as I've tried adjusting with 1/4, 1/2, 3/4 and 1 full turn on the nut for lifter pre-load after the lifter just begins to push down, and it makes the same noise no matter what.
I've even switched from roller bearing/tip rockers to plain stamped steel ones. and still the same noise!
The driver's side is fine.
The nut is not backing off as I marked it. Its pumping oil up thru the pushrod. Could the lifter not be holding enough pressure or something?
What else could it be??
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Oct 17, 2001 | 08:03 PM
Guest
Guest
Posts: n/a
Could be a bad lifter. It could also be a worn out rocker arm/pivot ball/stud. Could even be a really bad exhaust leak.
Old Oct 17, 2001 | 10:50 PM
airdeano's Avatar
when you adjust the valves and shut engine off..
observe the rocker arms after shut down. ive
be seeing a lot of bleed off (valves in open
postition close) even had new lifter clatter
because check ball not seating holding pressure.
some of the lesser expensive lifters have had
this similar problem. selaed power lifters
(johnson lifters) dont seem to have this bleed
off. just an obseravtion...
airdeano
gta892000
Aug 11, 2019 11:16 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Randomtask2
Sep 7, 2015 05:06 PM
