Guys who know about TPI sensore come in for a minute!
Im in a need of Some sensors i need a ESC(Electronic Spark Control) for an 87-89' 305TPI, I went to Autozone,Pepboy with no luck, GM wants $98.00 and ill be damned if i gotta pay $98.00 for a 3x3 inch sensor crap. One more question anyone know what are the sensors called that is located right in front of the Intake manifold for a TPI, I believe theres 2 or 3 there located in front of intake manifold and underneath the Throttle Body thanx
Get the part number from the dealer then go to gmpartsdirect. Just don't expect it to come in a hurry. BTW the part number I have for this is 16128261(may be for 350) and it is 44.16.
The "sensors" in the front of the intake are coolant temp sensor, cold start switch. There is also a third hole that is used for the throttle body coolant feed.
HTH
John
Heart of Texas Power and Performance
HTH
John
<font face="Verdana, Arial" size="2">Originally posted by robert1:
Try a NAPA store. I've come to love their parts, and the one year warranty!</font>
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
sensors on front of intake manifold:
large one: Temp sensor for cold start valve.
small one: coolant temp sensor- looks like air intake temp sensor.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC/LCA/PR, GW "wonderbar"
James
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have some sensors that I don't need anymore:
MAF sensor, ESC, MAF power relay, and MAF burn off relay.
If you need any of these, just send me email with your offer. I'll probably sell em cheap, since I don't need them.
WS6 Trans Am.
View My Ride @ thirdgen.org
WS6 Trans Am.
no thanx zephar i have all sensors now
. one more question the engine harness that i got was bought out of a guy who parts third gen cars and the connection switch from the harness that goes to the MAF was cut off, is their a place that i can get this piece????????? What exactly do u call it?????
. one more question the engine harness that i got was bought out of a guy who parts third gen cars and the connection switch from the harness that goes to the MAF was cut off, is their a place that i can get this piece????????? What exactly do u call it????? Supreme Member
They have the MAF pigtail at PepBoys. I was there yesterday. They had a large selection of weatherpack style connectors for almost every sensor in the car. I was surprised.
MAF pigtail was $10 or $15.
Oh, btw, those girls in my sig are friends of mine, I am a guy.
Sorry to to get your hopes up Cruz'N Bruz'R.
WS6 Trans Am.
WS6 Trans Am.
cool thanx for the maf pigtail advice one more question did 87'-88' TPI's have MAP (manifold Absolute Pressure) sensors on them??????????? i really need to know by tonight thanx
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Nope, no MAP sensors on the '85-89 TPI's, or even a vacuum fitting for one (although you could use a Y-fitting on one of the existing vacuum lines).
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
Engine: 385 HSR
Yep, mounted on the firewall on the driver's side next to the MAF and fuel pump relays. I replaced mine when I swapped out the 305 for a 355. I used the part number for a 350 since they were different part numbers in the GM parts manual (not sure if the parts are actually different inside).
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
Car: `86 SS / `87 SS
I also got a MAF extender harness from SLP 'cause I wasn't sure where my MAF was going to be in the ducting.
86 Camaro harness. 88/89 'Bird ducting to the PS... perfect fit
jmd
1986 SS with...
86LB9 TPI atop the original L69, Hooker emissions legal PN 2050 headers, stock L69 cat (yes, a real one), hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
jmd
1986 SS with...
ok something is going really wrong, Every thing is in, and i mean everything, The motor looks hot, and we started to crank it and nothing so we checked to see if any sparks was going through, it did, still cranks and nothing so my mechanic put a fuel line harness light indicator(which turns bulb on if injector harness is working) and nothing, We went throught the whole wiring and on the passenger side compartment where the computer is theres another wiring with a switch on it, it consisits of 3 wires and one gray switch attached to it, my mechanic says it needs to be plugged or attached to something in order for the harness to send power to the injectors, but where do they connect?? i dont see anymore switches on the computer? my other friend said maybe it mounts to the Fuse box. If it does do i have to rerout the wiring from the passenger side to the driver side? What connects to that switch someone pleas help me i really need to get the car done already.
Sanjay
Aug 12, 2015 03:41 PM
