TBI 305 Kock sensor
Old May 2, 2008 | 06:17 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
TBI 305 Kock sensor
Will a 305 TBI knock sensor work on a TPI setup? i am switchin to TPI from tbi and i wasnt sure if i had to get a new one or what ever
Old May 2, 2008 | 10:38 PM
Car: 89 Iroc z
Engine: 350 carbed
Re: TBI 305 Kock sensor
can anyone help me?? its a simple ?
Old May 3, 2008 | 02:57 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
as long as you stick with the 305 youll be fine using the tbi one.
Old May 3, 2008 | 03:23 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
You must change the knock sensor to a TPI unit. Check the Tech Articles section to confirm this.
Old May 4, 2008 | 07:40 PM
Engine: LO3
if the tech article is so right then how come a bunch of people have kept the tbi sensor when switching to tpi? and have gotten away with it. same block same sensor a 350 is a diff story.
Old May 4, 2008 | 11:15 PM
Car: 89 Iroc z
Engine: 350 carbed
so i should be good?
Old May 5, 2008 | 07:32 AM
Mongoose's Avatar
Car: 90 Formula
Well, apparently there must be some truth to it as I checked the part numbers for both TBI and TPI before I purchased for my swap and they were different. For those that still have the TBI knock sensor and no issues,
Old May 7, 2008 | 07:22 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
when i did my tpi swap i keep my tbi knock because i forgot to swap it
it causes ignition retard above 3500 i was pissed chouldnt for the life of me figure out what was wrong
then remembered i didnt do the knock swapped in the tpi one and it worked correctly
Old May 7, 2008 | 09:10 PM
Car: 89 Iroc z
Engine: 350 carbed
thx man
Dwayne614
Sep 28, 2015 08:33 AM
dutch930
Sep 11, 2015 06:58 AM
92purpz28
Aug 11, 2015 02:30 PM
