Scan tool - what do you guys recommend?
Old Oct 19, 2001 | 08:55 AM
BlazinOR's Avatar
Have a TPI 406 in my K5 Blazer and want/need a scanner to monitor the motor. My engine builder has a Snap On scanner that monitors everything, and I want something similar. Not sure on the Snap On price, but having spent many years buying Snap On tools, I KNOW it can't be cheap. Great stuff but way spendy.
So what do you guys recommend? Want the same basic capabilities as the Snap On. Don't want just a 'code reader' but something that tells me the TPS volts, etc.
Thanks in advance.
Old Oct 19, 2001 | 09:00 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Diacom, or Craig Moate's software if you have the '165 ECM. AutoX-ray (or whatever it's called) has a nice stand-alone scan tool if you don't want to buy/use a laptop...
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 19, 2001 | 09:16 AM
ede's Avatar
ede
if i were buying one to use on OBD 1 and OBD 2 cars and that i would actually use it i'd consider Snap-on. for ocassional use auto x ray gets mentioned a lot. you can buy diacom softwear and run it on a lap top. i bought a OTC monitor 2000 at a swap meet for cheap and it does quite bit but is limited on 93 or older cars.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 09:45 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am satisfied with my DIACOM program, unfortunately it refuses to connect to my dads caddy
Old Oct 22, 2001 | 10:10 AM
BlazinOR's Avatar
OK, for a handheld, what is the consensus here? Have a laptop but would prefer a handheld scanner.
Thanks!
Old Oct 22, 2001 | 11:28 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
where's the best place to buy Diacom and how much??can you use this to program??have laptop will learn
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
Old Oct 22, 2001 | 01:40 PM
Engine: 385 HSR
The AutoX-ray is probably your best bet for a hand-held scan tool, unless you have the big bucks for a Snap On scanner. You can get Diacom from here:
http://www.auto-ware.com/software_index.htm
No, you can't use it to program your own chips. The software to actually program chips will come with the burner. The software to change the tables and such w/in the program (bin) you can get from TunerCat, GMEPro, or use WinBin for free.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 22, 2001 | 11:31 PM
Earl 87gta's Avatar
This is what I use it works well an shows real time # Iv used the snap on scanner and I think this givs me just as much info
http://www.actron.com/cgi-bin/web_st...=4922485_17221
for more info on scan tools go to the tech articals and look up traxtons prom burning he has a section about scan tools an links to their sites.
Old Oct 23, 2001 | 12:00 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Anyone heard of this refurb deal?
http://www.autocheckup.com
89GTA-The Driver
92Z28-The Lawn Ornament
"Sunday Money"
Dkelz313
Apr 7, 2016 10:38 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
matthew911
Aug 12, 2015 09:38 AM
