AFR hydra rev(lifter problems?)
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I have an AFR hydra rev that I want to use, but my enginer builder says if I have the right springs I wont need it. He also says that they have been known to eat lifters/cams. Anyone had this problem??
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I've had the AFR Hydra-rev kit for a little over 2 years now, and with NO PROBLEMS. I don't know what he's talking about. I also know many 4th GEN guys with a Hydra-rev, and "R series" lifters included, and they work fine. Tell him to show you proof, and/or just install the damn thing. Remember, the springs in the AFR Hydra-rev kit, and all REV KITs, just PREVENTS the lifter from bounching on the cam, they DO NOT PUSH on the lifter plunger. I will be re-using mine with my CC P/N 875-16 "R" series lifter with my high revving 383. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/Fully ported 1990 Corvette L-98 heads/AFR Hydra-rev/ T-56 6-Speed/ PRO-5.0 shifter/ 1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I can see a rev kit adding too much pressure for flat-tappet cams, but the spring pressure from the rev kit shouldn't affect the roller cams.
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
88SS6speed, what does your car run?
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've had my AFR Rev Kit on my engine since February, and no problems with it. I've got pics if you wanna see it installed.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Kevin91Z, did you notice any difference or are you just using it more as an insurance kinda thing?
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
