Trying to get idle down
Old Oct 17, 2001 | 09:01 PM
airbrushguy's Avatar
1989 T/A 305 TPI...Set IAC and then set TPS (with and without ETS unplugged) at .540. New plugs, cap, wires,cleaned IAC and throttle body , Adjusted fuel reg. to 41, new fuel pump.... Idles at 900 and refuses to start when cold unles you give it two tries ( does not matter how long you held key first time, will not start till you let go of key and start again!!!)
Any suggestions? This is an automatic and was set with car in gear.
Car runs fine otherwise.
Old Oct 17, 2001 | 09:32 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Unless you have installed a different eprom (with a higher idle speed) or mis-adjusted the IAC; I would look for a vacuum leak.
Old Oct 17, 2001 | 10:43 PM
airdeano's Avatar
vacuum leak, MAF power relay? a scanner could
tell the fuel condition or pass key alert.
you might do a voltage drop test during carnking.
excessive starter draw disabling the computer
voltage?
some hints..
airdeano
Old Oct 19, 2001 | 01:52 PM
89Irocz23's Avatar
hey I have a question about IAC. Ok I set that and tps and everything is all good for about a week. Then its like the computer resets it self or some crap cause I gotta reset my iac.
Old Oct 19, 2001 | 03:41 PM
Checked all areas for vacuum leak...no leaks.
Do I have to diconnect the vac line on the AFPR before I adjust it? I've tried it both ways. Still idles 950-1000. Bought car used w/high milage...only last thought is that chip was changed,how do I tell?
Any other suggestions greatly accepted!!
Old Oct 22, 2001 | 10:03 AM
Anyone have any other suggestions...this is driving me crazy...???
Old Oct 22, 2001 | 07:25 PM
Desert86Roc's Avatar
How did you adjust your IAC? If you dont follow the procedure exactly, it wont work.
The steps are as outlined below.
· Key Off
· Attach TPS test harness
(allows multimeter to determine TPS voltage otherwise use a scanner)
· Insert Trouble code jumper
· Key On
· Wait 30 seconds (for IAC pintle to retract)
· Unplug idle air valve harness
· Key Off
· Remove jumper
· Key On, Start Engine
· Adjust Idle screw to correct rpm (650-700)
· Adjust TPS to .54 v using ohmmeter
· Key Off
· Replace idle air valve harness
· Remove TPS test harness
If you dont do it this way, the computer will just try to put it back where it had it in the first place.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
Old Oct 23, 2001 | 01:37 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Hook a scan tool up to see what the idle being read by the computer is as well as the commanded idle.
Old Oct 23, 2001 | 05:33 PM
Bugsbunny's Avatar
Try tightening your runner and throttle body bolts just for the hell of it. You never know.
Bugs
[This message has been edited by Bugsbunny (edited October 23, 2001).]
Old Oct 24, 2001 | 09:40 PM
Desert86Roc: Is it necessary to disconnect ETS( ignition timing plug) ? in this process?
Old Oct 25, 2001 | 01:05 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You only need to disconnect the EST bypass if you're setting timing.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
