Is this cam OK with my mods.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am considering one of 2 comp cams designs.
the mild one is their 08-501-8 XR 264 HR grind and is says for stock tpi's
I think this is the limit my pressed in studs could take at .488I .495E lift.
But I am planning full length headers and I already have headwork and intake work but the stock transmission and 3.23s are still there. I would like to get their 08-502-8 XR 269 HR grind to accent the mods Ive done plus the fact that I will get 3.42s and plan to get the tranny rebuilt with a stall converter to match.
I guess my questions are -- should I go with the bigger grind for all the modifications I plan or will it pull out my studs with it's .495I .503E of lift?
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts, PST front end poly stuff, Earl's hyperflex brake lines SSM SFCs, Bilsteins very trick homemade ramair, Accel 300+ ignition system. Ported plenum, intake and heads with 1.94I valves.
Planning: Heddman 1-5/8 longtubes, NOS 150 plate, replace the "peanut"! and Eibach Sportlines.
check it out at:
http://www.geocities.com/transam617
check it out at:
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
depends on how soon you'll uprade your tranny a tourqe converter as well as intake.i prefer to change a cam only once,either waiting till i get all the parts or dealing with an overcammed engine for a bit.your choice either way.check out the small-mid slp grinds or the accel grinds.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
[This message has been edited by PETE (edited October 28, 2001).]
best e/t:
