Stock pushrods.....?
Old Oct 29, 2001 | 05:40 AM
Cam28_boy's Avatar
Does anyone know if the stock pushrods are hardened or not?
1991 Z28 5.7L
All free mods/afpr/hurst lock up harness/flowmasters(off)/lakewood Lca's/accel stock size injectors/msd6A-plugs, ignition coil/k&n/lakewood adjustable panhard rod.
1/4mile 13.7@102. Expected et next outing 12.9@? (with slp 1 3/4 headers and new ported sportsman II heads along with 24lb injectors, adjustable torque arm spohn or bmr)
Old Oct 29, 2001 | 11:11 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I don't know for sure, but I'm guessing no. Hardened pushrods are about $35 bucks... Comp Cams
Old Oct 29, 2001 | 11:54 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
stock pushrods are typically carbon steel tubes with hardened ***** welded on the ends. The pushrods that alot of aftermarket guys sell are one piece and are hardened as a single part. Which is better? well, the factory is adequate for normal stock type seat pressures, but as you increase the spring pressure, better units are mandatory. You would be surpised how much the stock ones can handle though, if you are re-using them and not going overboard with springs, then just make sure they are straight(roll em on a peice of glass and make sure then don't wobble) and you will be fine. If you have to buy some, get some aftermarket ones, probably only pay a few $ more, and can be used if you ever decide to go bigger.
Old Oct 29, 2001 | 12:02 PM
Cam28_boy's Avatar
Thanks for the replies. The reason I asked was because i'm putting new cylinder heads on and they have guide plates, I know they say that you should use hardened pushrod with guide plates. Can I make it with the stock pushrods?
Old Oct 29, 2001 | 12:16 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
So you bought new heads with guideplates and you're going to get cheap on the pushrods? Spend the $35 bucks. You are going to spend it now or spend it in a month when your pushrod buckles due to a severely decreased wall thickness, but then you have to buy new intake manifold gaskets and worry about little pushrod shavings floating around in your oil pan. I vote new pushrods.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Oct 29, 2001 | 12:18 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
You better buy new headbolts and decent head gaskets too!
Old Oct 29, 2001 | 12:27 PM
Cam28_boy's Avatar
I have all new fel-pro gaskets and arp bolts. I will just have to wait to order some new pushrods...damn!
1991 Z28 5.7L
Old Oct 29, 2001 | 01:39 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
hey cam28 boy, where did you run those times?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Oct 30, 2001 | 06:05 AM
Cam28_boy's Avatar
Hey GoFaster, I ran those times @ Lapeer dragway, about 2 months ago. After I but these sportsman II heads and torque arm on, I plan on running a 13.0 or even a 12.98.
1991 Z28 5.7L
Old Oct 30, 2001 | 10:52 AM
Cam28_boy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GofasterFirebird:
</font>
I ran those times about 2months ago at lapeer dragway. I'm expecting even lower times with my next wave of mods.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
