MAF Problem, need help!
Old Oct 30, 2001 | 11:26 AM
Steve R's Avatar
OK, every now and again when I start my car, it'll run for a second and then crap out. It'll only stay running when i hit the gas but then it craps out when I let off the gas.
Every now and again, a Code 34 comes up.
What's causing this?
It's on an '89 ASC GTA, L98
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Oct 30, 2001 | 11:38 AM
nblanchard's Avatar
Before you get a new MAF sensor!!!!!!! Replace the MAF relay located on the drivers side firewall... should be the middle one. I had the same problem, but my car actually stayed running, barely though. The relay is a common problem on the TPI. Its a lot cheaper than 400bux for a MAF sensor. Go to the dealer and pick the relay up
Old Oct 30, 2001 | 04:32 PM
breathment's Avatar
isn't 89 speed density? therefor its the MAP sensor? right?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 30, 2001 | 04:43 PM
Momar's Avatar
No it is maf. Speed density didnt come until 90 in the vetts and 91 in the camaro/firebird.
Old Oct 30, 2001 | 05:30 PM
breathment's Avatar
oh my bad, its the cold start injector that they changed in 89. sorry
- David
Old Oct 30, 2001 | 05:47 PM
Steve R's Avatar
Thanks! Unfortunately someone messed up the bracket, so I have a bunch of relays sitting there. Does anyone have a part number for the power relay?
The burnoff relay wouldnt cause that would it?
Old Oct 30, 2001 | 06:21 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
There are three relays on the drivers side firewall of your car. Two of them will have the same part numbers (and be oval in shape). Both of those are for the MAF. One is the burnoff relay, and the other is the power relay. I'd recommend replacing them both. Almost any parts store should carry replacements.
'89 TA - 5.7 TPI (L05, was originally a 305TPI), T5-WC, 3.08 Posi (Drum)
Old Oct 30, 2001 | 09:47 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
They happen to be the same spec. as the ones that control your fans (which are in the passenger fender) on the 89.
Can you rev past 4k?? I had a weird MAF problem when I finished the motor, cuz the green wire was split.. It would run like crap, and wouldn't rev past 4k.
-- Joe
Old Oct 31, 2001 | 10:17 AM
nblanchard's Avatar
beg to differ.. the two same relays are NOT for the MAF sensor, one is for the fuel pump, one is for the MAF, then there is a smaller one for the MAF burn off. I believe the one you want is the one with the black connector (there should be a grey and a black one for the two similar relays) Hey.. you can even try swapping the 2 relays the next time you have the problem... that should eliminate the problem, if that is the problem.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Oct 31, 2001 | 05:52 PM
Steve R's Avatar
Yeah, It doesn't like to pass 4k either.. which green wire are you talking about?
chazman
Aug 28, 2018 03:25 PM
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
masonta
Sep 1, 2015 06:40 PM
Bert87
Aug 23, 2015 03:50 PM
