alittle issue that annoying me...
Old May 14, 2008 | 12:57 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
everytime i start the car for the first time that day, weather its morning, noon or night. itll run for about 3-5secs then die. but if i start it and goose the trottle it start and run w/o dying. any ideas what may be causing this?
Old May 14, 2008 | 11:02 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: alittle issue that annoying me...
well im leaning towards a possible IAC problem, has anyone got any insight?
Old May 15, 2008 | 08:10 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
TTT
Old May 15, 2008 | 08:30 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
youre probably right, iac and tps go back and reset them both,technicle articles on homepage has a great article on how to set them properly.later jimmy
Old May 15, 2008 | 10:03 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
i reset the TPS awhile back after i bought a new one. since ive owned the car i have never reset the IAC so i think i need to. i got a used MAF sensor which did make a world of difference when i was troubleshooting another problem. i goona try and clean and reset the IAC and see what the results are.
Old May 15, 2008 | 10:22 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
let me know how it turns out,later jimmy
Old May 15, 2008 | 11:20 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
will post results when i can get to it hopefully this weekend.
Old May 23, 2008 | 05:31 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
the IAC can be cleaned correct? if so what is a safe cleaner to use? regular carb or TB cleaner, WD40, what????
Old May 24, 2008 | 12:40 AM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Take the IAC out of the TB and clean the passageway with carb cleaner. Reset the IAC and TPS according to the tech article. It did wonders for my car.
Old May 24, 2008 | 01:00 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Let me know what happens navy.Got a similar problem myself.
Old May 24, 2008 | 02:35 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
will do...
GTAman
Jul 3, 2024 07:29 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
