gaskets to use for port matching intake
Old Oct 31, 2001 | 07:27 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
hey guys i was surfin the archives about portin heads and intakes because i am gonna port mine and install a cam this winter. gaskets came up in one of the discussions. it was stated that replacement felpro, and GM gaskets had too small of openings. what gaskets do you guys suggest? i can get GM gaskets at a good price through my dad, what woudl i have to do to make them work? what would i use to cut them? dont some have a metal core in them? thanks for all your help
86 IROC
43,000 miles
305/700R4/3.23 gears
maroon, gold stickers, black interior, T-Tops.
current mods.
shift kit
headers
cat back exhaust
mods planned for this winter
cam
3.73 gears
subframe connecters
Old Oct 31, 2001 | 07:30 PM
craiger's Avatar
flepro 1206
Old Nov 1, 2001 | 10:33 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
ok is that a whole TPI gasket set from Throttlebody to Base, or is only runner gaskets or what?
Old Nov 2, 2001 | 04:07 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
That is only for the base. Try the dealer for a set of gaskets for the runners only. you will be amazed at how poorly the factory port matching is of the TPI system and heads - even with the stock gaskets. My OEM gaskets stuck out about a 1/16" in a few places!! If you really want to hog out your TPI stuff, get a set of the Large Tube Runner gaskets from TPIS and do your best to match everything to them....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Sep 8, 2015 03:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89-S-dime
Aug 12, 2015 11:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
