WHERE DO YOU GET THE NEW VORTECS???
Old Oct 30, 2001 | 12:56 PM
85transamtpi's Avatar
I'm talking about the vortec heads that will bolt right up to my tpi setup...where can I get them? Ive heard some people talking about these and havent been able to locate any.
thanks
Old Oct 30, 2001 | 08:25 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Thats new, I would be interested too.
John
Old Oct 31, 2001 | 08:21 AM
Anyone know about these?
Old Oct 31, 2001 | 08:54 AM
BitchinCamaro's Avatar
I have heard about these... from what I understand the new bolt holes run real close to the water passages and have a tendacy to strip. Most companies that used to sell the double drilled vortecs have stopped for those reasons. Regardless of bolt pattern the ports don't line up and you are going to have some major turbulence. Just my 2 cents.
Old Oct 31, 2001 | 02:05 PM
SoCo80p's Avatar
there on 89 and newer vans and trucks, you might be able to find some in a junkyard or elswhere, i havent come across any in the junkyard but at the last swap at the fairgrounds i saw 3 diffrent sets for about 250-300$ which is a pretty good deal, they flow better then the old double hump heads, the TPI setup ****should**** would as these have the newer style bolt pattern, only downsides is they will only take a .470 lift cam and need a self aligning roller rocker (expensive) but for there price a good choice for a street/mild strip engine. heres a link for a pair of brand new ones..
http://www.sallee-chevrolet.com/Cyli...ds/Vortec.html
Old Oct 31, 2001 | 03:04 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Actually, Vortec heads weren't in use until 1996.
Old Oct 31, 2001 | 03:06 PM
SoCo80p's Avatar
right my mistake,
Old Nov 2, 2001 | 02:12 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
you can get NEW fully assembled vortec heads from GM performance for $450, then you would have to buy a scoggins dickey vortec TPI base. That is the better way to go vs. getting the vortec heads drilled and tapped for the stock base.
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
