Throttle position sensor..........Help
Old Nov 8, 2001 | 07:08 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
When checking my throttle position sensor,it bounces around. The numbers go from .547 then to .543 then to .549 and so on. The fluctuation is there, with sensor tight and just probes connected. Is this the way it should be, or is this a sign of failing. Is on a 1987 TPI 305. Thanks.
Old Nov 8, 2001 | 07:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Maybe check another low voltage source with your meter, could be just noise.
A 40mv fluctuation wouldn't be anything I'd be concerned about, I don't think the TPS scales in the EPROM have that much resolution?
Old Nov 9, 2001 | 11:45 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Yeah, that's nothing to worry about, especially since the highest accuracy I've seen from a scan-tool is 2 decimal places. Mine goes changes a couple hundredths just from the engine warming up.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 9, 2001 | 12:34 PM
slowpoke's Avatar
Car: 1987 Z28
I was curious of it, because I have off idle hesitation. It's starting to get poor fuel economy. Was around 20 to a gallon now around 16.5. These are a few of the things I've done: new AIC, Bosch platinum plugs, new 8.0 wires, and the cap and rotor. Any other ideas would be great. Thanks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
