Rough idle and check engine light
Old May 23, 2008 | 07:17 PM
Samdweezel05's Avatar
1989 GTA TPI 350. Idles rough and check engine light is on when it is cold. Once it warms up you can shut it off and restart it and the light stays out but the idle is still rough. MAF has been replaced by previous owner. I am thinking it is the O2 sensor but the TPS and the IAC are in my mind as well. Who makes a good inexpensive scaner to read the code when the light comes on?
Phil
Old May 23, 2008 | 11:08 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: Rough idle and check engine light
jump your ALDL w/ a paperclip. no need for an expensive scanner to read it. this will tell you what the code # is. buy a chilton's manual and find out what the code is.
Old May 24, 2008 | 06:20 AM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Do a search for rough idle on this forums, you will find your answer.
Old May 24, 2008 | 05:34 PM
I forgot about jumping A and B on the ALDL. I did that on my beretta a few times. I have a chiltons allready from my last 87' IROC. Thank's
Phil
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
