What the hell was that?!!?
Old Nov 9, 2001 | 11:49 PM
OldBlue's Avatar
Ok I was in a race tonight, the car hit 2nd gear, went up to around 3500 RPM then all the sudden just lost power and started back firing?!? what would cause this? the fuel pump is brand new so I dont think that would be it, and the car didnt spit any codes. do you have any ideas what might cause this? its never done this before. then just driving around normal it was perfect, get on it again and it would start back firing. I dont get this, maybe its running rich? or maybe way to lean?
Old Nov 10, 2001 | 12:08 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Might have a toasted plug wire or two, or a fouled plug or two. Check the wires for signs of arcing and pull a plug or two and give them a look.
Some ideas......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 10, 2001 | 12:25 AM
OldBlue's Avatar
whats the easiest way to get at the plugs? I ahve gorilla arms and there is no way I can get my hands down to change the plugs on my TBI camaro let alone this.
Old Nov 10, 2001 | 12:46 AM
Fastcamaro87's Avatar
ok get some extensions and some swivels, as well as a spark plug socket that has the area for a wrench to be put on it,
you should be able to get to the 2 front spark plugs on each side from up top, however i have found it much easier to get to the back 2 spark plugs on each side from underneath the car,
also another thing you might want to check is the ignitoin module, and possibly the pickup coil on the distributor...
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Gutted Cat, Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 10, 2001 | 11:07 AM
Vader's Avatar
Blue,
Maybe I should loan you my "orangutan" arms. I can change all my plugs from the top, but it does require some creative combinations of sockets, wrenches, extensions, swivel ratchets, contortions, Tantric/Mensa positions, and determination.
The more difficult plugs are #8, #6, and #5. #2 can be a real treat, too. If you have all the factory plumbing, AC, and the master cylinder/prop valve in the way, it's going to take some time. #6 and #8 are easier if you use the plug socket and a wrench that fits the flats on the socket, them spin it out by hand.
After you do this a couple of times, you'll appreciate a little anti-sieze on the plug threads to allow them to be installed and removed by hand more easily.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 10, 2001 | 07:37 PM
OldBlue's Avatar
I ahvent had a chance to get the plugs out yet, but Ill do that tommarow along with finishing the rotors and brakes. oh Im just jumping for joy im gonna avhe so much fun lol anyhwo thanks, I'll let ya knwo what happens tomamrow
Old Nov 11, 2001 | 01:29 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I really second that ignition module failure. Just judging from your description, I doubt it is spark plugs.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 11, 2001 | 04:08 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
third on the module possibly being bad. a good way to check is when the car starts misbehaving look at the tach. if it drops to zero it is usually the module or a ground somewhere.
Old Nov 13, 2001 | 11:41 AM
deepsouthz28's Avatar
Car: 87 IROC
My Z was missing, and backfiring as well after humbling a 5.0.(old one) I changed to BOSH PLATNUM plugs. The guy at the Chevy dealership told me that my injectors seemed to be "pouring" fuel in more than "spraying" it. He told me to put some hotter plugs in. The BOSH plugs (I was told) Do not foul as easily, thus a lesser chance of missfire due to fouled plugs. I put the new plugs in, with good quality 8mm wires, and it now runs very smooth, with better response. I am getting new injectors soon.
Just my .02$
86 Z-28,305,700r-4,t-top.
"DRIVE IT LIKE YOU STOLE IT!!!!!!!!!!"
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
