Calling all TPI guru's..Bad Canoodle Valve???
Old May 29, 2008 | 05:18 PM
pa_richardson's Avatar
Thanks for reading this thread..
Okay i have a 350 tpi running on SD set up 1999..
I have changed many parts to fix this but giving up hope...
The engine will run and idle (sometimes) a bit rich as you can smell it and see smoke.
The engine will warm up and either run but mostly it will then die just like you turned the keyoff...Then trying to start will just end up in wet plugs..
If the engine does run once you shut it down and leave it over night it will not start the following day it will just turn over then just flood itself silly...
Parts i have changed include...new ecm,tps, iac,temp sensor,dizzy, pick up coil,leads,plugs,oil,o2,fuel,fuel regulator...I have checked vaccuum, all wires, grounds,power and clean throttlebody, i even sprinkled some magic dust over the engine..
I have looked and injectors and pressurized the rail whilst the injectors were out and they dont seem to be leaking but im no mechanic...
What do you guys think please help me im struggling and have tried so hard.
Im wondering about faulty injectors?(but all 8???not sure)maybe the Memcal,
maybe the canoodle valve is broken....only kidding..
Old May 29, 2008 | 06:16 PM
tpi user's Avatar
Re: Calling all TPI guru's..Bad Canoodle Valve???
did you check injectors,test them
Old May 29, 2008 | 06:20 PM
Hi i did check the impedance of each one all at 17ohm if i remember...
Also i placed test light on the input and can see a pulsed supply when engine is cranking..I am seriously concidering getting them replaced or cleaned for piece of mind that its a fix or to rule them out..
Old May 31, 2008 | 06:08 PM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
Does the TPI computer use coolant temperature in closed loop?
Old May 31, 2008 | 06:34 PM
I have not changed anything in ecm and i hae replaced the Coolant temp sensor ... i amnot sure if it uses it sorry..i
Old May 31, 2008 | 06:35 PM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
are the injectors the correct flow rating? fuel pressure test? do you have the correct prom? sounds like its just pumping too much fuel in
Old May 31, 2008 | 06:52 PM
I think your right...i have no idea what size the injectors are or if there working 100% also i have no idea about prom so i have just ordered new injectors and a programed prom to match my setup from http://www.scotthansen.net/ he is very helpful and knows his stuff i will let you know how it goes once i recieve delivery over the big pond....
Old May 31, 2008 | 07:33 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Injectors:
Look on the actual body of the injectors themselves and find the part number, then write it down and google it.
Plug wires:
What kind and do they have any burn marks on them? I used to burn through plug wires all the time when they hit the manifold. All it takes is a tiny crack and you will get a bad miss that will drive you crazy.
Timing:
Is your timing set correctly? If you swapped the dizzy and installed it 180 degrees out its never going to run correctly no matter how many parts you replace.
IMHO it sounds like its ignition related, (without actually seeing the car)
Old Jun 2, 2008 | 08:07 AM
jreze8's Avatar
Car: 1991 Iroc Z28 Camaro
Engine: 5.7L V8 350CI
Transmission: Stock
Axle/Gears: Stock
My car was flooding the injectors and doing basically the same thing. Replaced the injectors, runs great!
Old Jun 2, 2008 | 04:34 PM
The plug wires are new and have checked timing an had it running..
Waiting in new plugs Jeze8 so hopefully like yours it will run great yet again.
backtothe80s
Sep 5, 2015 12:39 AM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
