tpi running rich
Old May 30, 2008 | 10:41 AM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
tpi running rich
My buddy has a 87 camaro tpi. we are not sure if its 350 or 305, the stock hood says 305, but the guy he bought it from said 350..but it doesnt look like the motor was ever replaced...anyways, at idle it runs so rich the exhaust makes your eyes tear and its almost unbearable. there is no ses light, any ideas? I am thinking its his o2 sensor. thanks
Old May 30, 2008 | 11:26 AM
Pocket's Avatar
Car: 91 Trans Am
Re: tpi running rich
Vin 8 = L98
If you suspect a swap get a mirror and flashlight
On the rear of the block near the dist there will be a 5.0L or 5.7L cast
Running rich:
Start with the fuel pressure, what is it
Are all 8 cyls firing correctly (check plugs)
Ground out the ADL port and check for codes, simply not having a SES light all the time does not mean there are no codes stored
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
