where's an article on modifing a LT1 intake for an older small block
Old Nov 12, 2001 | 09:31 AM
zboss86's Avatar
I was surfing the internet the other day and I saw a topic where they were telling how to modify a LT1 intake to fit a older small block.
I thought I book marked it, but didn't. It was on one of these gm sites. Could any body tell me were it is?
Old Nov 12, 2001 | 10:16 AM
BitchinCamaro's Avatar
Here ya go
http://sethirdgen.org/LT1.htm
Old Nov 12, 2001 | 01:45 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Find the original here: http://members.home.net/millicanga/ on John Millican's website.
Old Nov 13, 2001 | 06:42 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its just about the same thing.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited November 13, 2001).]
Old Nov 13, 2001 | 07:09 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Nov 14, 2001 | 09:44 AM
zboss86's Avatar
thanks guys you all are the Best!
Old Nov 14, 2001 | 10:12 AM
<font face="Verdana, Arial" size="2">Originally posted by John Millican:
</font>
^^^^Thats the guy you should be thanking.
Old Nov 14, 2001 | 01:41 PM
zboss86's Avatar
Hey John,
will I need the LT1 fuel rails also or will my tuneport rail fit?
What about the throttlebody will the tuneport fit or do I need the LT1 throttlebody?
[This message has been edited by zboss86 (edited November 14, 2001).]
Old Nov 14, 2001 | 07:47 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by zboss86:
Hey John,
</font>
You will need the LT1 fuel rails.
You can use either the TPI TB or the LT1 TB.
[This message has been edited by John Millican (edited November 14, 2001).]
Old Nov 18, 2001 | 01:10 PM
zboss86's Avatar
Is there any specific sensors I'll need when I find an intake? I'm not sure what came with the LT1 intake. I see alot of bare intakes. I can get the fuelrails seperate. It's getting hard to find a complete LT1 intake.
I still have the sensors on the Tuneport intake. I don't know if there the same.
I won't be running egr. I'll also be running fel-pro speed-pro unit.
Old Nov 18, 2001 | 02:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
</font>
Depends on what throttle cable you want to use. If you use the TPI Throttle body, you can use the stock throttle cable. If you use the LT1 throttle body, you will have to buy the LT1 throttle cable. John and I found this out the hard way. If you need an LT1 throttle cable, I have one for cheap!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
