Engine tries to start...fuel pressure problem? (Video Inside)
Old Nov 18, 2001 | 08:32 AM
S10Wildside's Avatar
I just tried to start my 355 TPI last night. It fires right up, runs for a second, then dies. The fuel pump runs for about 1 minute every time the engine stops!! What's up with that?
I hooked up my fuel pressure guage. I'm getting 40psi when I turn the key to ON. As soon as the engine fires up, the pressure drops suddenly to 30 psi, the engine shuts off, then the pressure goes to 40 psi.
I have an AFPR, but it should not need adjustment because the engine ran fine before I took it out of the vehicle.
The only thing I changed with the fuel lines was replacing them with braided stainless. There is one fitting that does restrict the fuel feed line...blocking about half of the diameter of the line. Could this be the problem?
<a href="http://www.personal.psu.edu/users/m/d/mdn124/wildside/firststart.mpg">Click Here</a> for a video of the engine trying to start.
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, Sanderson Ceramic Coated Headers 1993 Typhoon Drivetrain
Old Nov 18, 2001 | 02:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It'll take me 4 days to download a 1+meg file on my modem line...
Do you have a MAF sensor? If so, could be it's not secured well to the ductwork, or the duct is craked/split.
Also, make sure the duct is on securely to the TB
Old Nov 18, 2001 | 02:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Also, the FP could be running due to residual pressure in the oil pressure switch, a minute does seem kinda long though...mine always buzzed for about 5-10 seconds, max
Old Nov 18, 2001 | 02:55 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
</font>
Thats what finally convinced me to get DSL. About 3 seconds till showtime
I don't think its a fuel problem. It should run rather well w/ 30psi. Spray some carb cleaner down the TB and see if you can't keep it running. If so, then you do have a fuel problem, or the injectors are shutting off.
I can tell by the pic that you put a Corvette engine (alt bracket is a dead givaway) into an S/T truck/utility (the digital dash is the dead givaway) That looks like it will be one bad ride. Good luck.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 18, 2001 | 03:03 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The FP going down is normal; the FP is controlled through the FPR via vacuum. As soon as the engine starts, you have vacuum which reduces the FP.
Without scan data, it's difficult to say what your problem is.
That said, I had a problem where my car would start and run for a second and then quit. Ended up needing to burn a new chip.
Old Nov 18, 2001 | 03:48 PM
Figured it out...I had a wire going to the wrong place on the starter. It runs now...and breathes fire with open headers!
1982 S-10 Wildside
Old Nov 18, 2001 | 04:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Heh, that will do it! Glad you got it running.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
