TPI Auto to Manual Trans
Old Jun 2, 2008 | 11:18 AM
mitchcoxkc's Avatar
Car: 1962 Chevy Nova
Engine: 383 TPI
Transmission: 350 Turbo
I have a 1962 Chevrolet Nova with a 383 with Dart Pro Alum 180cc heads with 72cc chambers and flat top pistons. I'm using the 1988 prom currently for an auto trans and a Painless wire harness. I just switch to a Tremec TKO600 5 speed and am having some issues with the speed sensor. The Tremec comes with a GM 10456568 sensor installed. I hooked my VSS wire to the sensor and grounded the other side. I'm getting a VSS code now when I am driving down the hwy..
The other question is (I'm not chip begging) which prom should I use and who is a good person or company to use to burn a custom chip..
Mitch
Old Jun 3, 2008 | 08:58 AM
mitchcoxkc's Avatar
Engine: 383 TPI
Re: TPI Auto to Manual Trans
Anyone???
Old Jun 3, 2008 | 09:13 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
i would start from the vss. the one you have is for 95~2000 (based on part number) and i think those vss have a diffrent output signal than the one they came on 3rd gen camaros 4000ppm vs 2000ppm. for the prom, do you have SD or MAF?
Edit: I see that you have 88 prom, in that case I would start with this bin APYP
Old Jun 3, 2008 | 10:25 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You might need to hook the ground on the sensor to the proper one from the computer.
Old Jun 3, 2008 | 11:24 AM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
http://www.5speedtransmissions.com/3...y_package.html
I found very useful and will buy a tremec from them
Old Jun 6, 2008 | 02:40 PM
mitchcoxkc's Avatar
Engine: 383 TPI
I did purchase the Dakota Digital magic box and am hooking it up today. I'm still wondering about the EPROM. Any suggestions.. And I am running the MAF system.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
1nastygta
Oct 28, 2015 08:51 PM
Sanjay
Aug 12, 2015 03:41 PM
