having probs?
Old Nov 19, 2001 | 08:05 PM
89tpi's Avatar
having probs?
I just got a MSD blaster coil and 8.5 wires for my 350 TPI and the engine is idling rough and smells rich. Why is this and is it part of the chip processing it or do i need to do something? The engine is stock other than this.
Old Nov 19, 2001 | 08:34 PM
89tpi's Avatar
It also is sounding a lot louder and nothing else was messed with. Is it possible one of my plug wires might not be on good enough?
Old Nov 19, 2001 | 08:50 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
or you might have crossed some onto the wrong plugs. the two in the middle on the pass side are easy to get mixed up.
Old Nov 19, 2001 | 10:13 PM
89tpi's Avatar
ok but is there a chance the coil itself is causing this? Also a friend who helped get it in and go to get it said that the computer needs to adjust to the new coil is that true? And is the rich carb smell from the coil cleaning the car out?
THANKS
Old Nov 20, 2001 | 11:48 AM
89tpi's Avatar
anyone else i would greatly appreciate it?!?!?
Old Nov 20, 2001 | 11:56 AM
BitchinCamaro's Avatar
The computer will need to adjust to the changes, but that shouldn't take more than a matter of seconds once the car is warmed up. Start by going back through everything you did and make sure you didn't leave a wire loose or some simple mistake like that.
84z96L31vortec
Aug 20, 2017 12:16 AM
billybob6110
Sep 24, 2016 09:50 AM
customblackbird
Oct 1, 2015 04:30 PM
89 formula TPI
Sep 8, 2015 08:00 PM
z28addict8490
Sep 5, 2015 03:56 PM
