can an 86 distributor be used in an 89 block?
Old Nov 23, 2001 | 06:00 PM
Steve86TA's Avatar
Car: To many to list
I will be replacing my 86 tpi 305 with an 89 tpi 350.Will the dist. from the 86 work in 89 roller block with no problems?
Old Nov 23, 2001 | 06:29 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You will have to change the wiring and remove the external coil. Yes it will work.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
[This message has been edited by John Millican (edited November 24, 2001).]
Old Nov 24, 2001 | 12:36 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You will also need to change the gear, as the '89 has a steel camshaft.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Nov 25, 2001 | 05:30 PM
Steve86TA's Avatar
I know about the wiring being different,but will the cam gear swap over from the 89 to the 86 dist. with no problems?
Old Nov 25, 2001 | 07:17 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Actually I heard that the dist. gear in all the thirdgens are the same because GM used the same type of gear on the roller cams as they did on the flat tappet cams. Now if you're putting an aftermarket roller cam in there then yes, you will have to change the dist. gear.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Loudnproud86
Jul 14, 2016 12:59 AM
camarohelp
Sep 22, 2015 03:19 PM
BLK87Z
Sep 18, 2015 11:29 PM
RyanJB
Sep 14, 2015 03:39 PM
Jlanz55
Sep 6, 2015 03:05 PM
