tpi wiring
tpi wiring
i have a maf tpi setup that i got with the wiring harness to the WHOLE car. can someone PLEASE tell me where i can get a book or something that gives wiring diagrams to get all the wiring needed for the tpi out of it?
I ordered the GM manual. I believe that the company is called Helm. The price was about $92.00. The schematics take some getting used to but if you hang in there it becomes clearer. Good luck.
88 IROCZ28
ZZ4, Big Mouth, Lg. runners and BBK 58mm TB. 700R4 w/ corvette shift servos, 3.23 Borg Warner & posi.
B&M 2400 Hole Shot and MegaShifter. Random Tech Hi Flow Cat and 3" Catback system, Edlebrock headers - jet coated.
88 IROCZ28
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Get the Chiltons for YOUR CAR not the general book. Should be about an inch thick and available at most bookstores. It has copys of the FACTORY wiring diagrams in the electrical section. Much better then the Haynes crap.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
86 Camaro Sport
LT1 Induction
My Camaro Project
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi,
The chiltons stil suck as far as wiring diagrams tho.
Do you have any questions about certain connectors, or are you just lost in the woods?
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
-- Joe
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
If you call Helm Inc. and ask about another source for a manual they should give you two other numbers. One being Faxxon (where I bought my GM manual) and I can not remember the other.
Of course another source would be ebay.
HTH
HTH
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
1-800-manual9
Rick & Mindy
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Rick & Mindy
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
14.94-92.00 mph
1989formula5.7l
Aug 17, 2015 02:56 PM
Sanjay
Aug 12, 2015 03:41 PM
