car nead help
Old Jun 17, 2008 | 07:08 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
car nead help
I just got a 1987 factory yellow hard top IROC-Z 305tpi today. When i got it the previous owner said that the fuel pump had gone bad but they replaced it. after they replaced it they drove about 15 miles and it stopped. it started back up and they drove it home but after it had set overnight they could not start it. now when i got it i sprayed starter fluid in the intake and it will stay running, but without the starter fluid it will start for maybe a fraction of a second and then die.new relay i replaced the fuel filter, while i had the fuel filter off i had someone turn the key to the position before starting so i could see if gas came out and it did. That did not fix the problem. does anyone have any ideas of what else it could be?
Old Jun 17, 2008 | 10:39 PM
JesterHead1651's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
Re: car nead help
im really stumped, i think your best option here is to just......man cant believe im goin say it...take it in
Old Jun 17, 2008 | 11:24 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: car nead help
Wow. One post, and you say take it in? This *is* a tech board, after all.
To the OP, what's your fuel pressure like? Beg/buy/rent a gauge to test it. I can't think of any further diagnosis without that info.
Old Jun 17, 2008 | 11:41 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: car nead help
first thing that comes to mind is the cold start injector . check to make sure the egr is not stuck open . cts could be bad but i doubt it .
if you let the motor get hot (till the fan comes on) and shut it off will it start right back up ? once you get it going how good does it run ?
p.s. "JesterHead1651" learn more or get another hobby ....
Old Jun 18, 2008 | 12:53 AM
Engine: 305 tbi
Re: car nead help
see i just do not i mean you spray starter fluid in it it will only run till it burn off fluid and it dies off i do have a pressure gauge but it does not have the right fiting but it does shot up in the are when you push the check point is there a way to check to see if the injector fuel are fireing ???? i dont know what to do any more only think is its the injector or ecm
Old Jun 19, 2008 | 05:01 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: car nead help
you'll need to retype that last post because it does not make any sense .
till you can get a pressure guage on it theres not much you can tell . it needs 40lb of pressure , youll get fuel to come out of the fuel rail fitting even if there is 10lb but i doulbt it would start .
Old Jun 19, 2008 | 05:31 PM
Russ-So Cal's Avatar
Re: car nead help
You have a 1/4 inch flare fitting with a schrader valve on your fuel rail. Get a hose for r12 refrigeration gauges, a 1/8" pipe thread to 1/4 flare half union. and a mechanical pressure gauge. Assemble everything and you will have a tool to measure your fuel pressure. You have to find out what your fuel pressure is before you can go farther unless you have a calibrated eye that can tell the difference between 25# and 40# by the spray pattern.
Old Jun 19, 2008 | 09:37 PM
Engine: 305 tbi
Re: car nead help
well i am get 41 psi and i change the ecm with 1 out of a running iroc-z and it still will not start i am just out of things to try driving me crazy
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
