Idle problems.
Old Dec 9, 2001 | 03:32 PM
ramair89's Avatar
Idle problems.
I have an 89 Formula 350 that I am having idle problems with. It kicks up the SES light every morning and has the EGR code in the system. We replaced the valve and it didn't solve the problem. It hunts for idle at stop lights surging up and down. It has died in the past. It seems to run worse when it gets warmer out side. If I broke it out of storage now it would run good till it got hot outside. We have tried cap, rotor, plugs, plug wires, TPS, Baro sensor, O2 sensor, ECM, and I even took it to a dealership. They told me that I had 6 bad fuel injectors and that it would be $1500 for new ones. I don't think that the car would even run with 6 bad injectors. I am getting pretty frustrated. Fortunatly the car only does it at idle, if you give it gas it is fine. I don't even to have any lost HP. If anyone has any suggestions it would be great. I don't know what I would do having my car idle right again! Thanks!
Old Dec 10, 2001 | 01:32 PM
my89formula350's Avatar
hi i had the same prob and i did have some bad inj not bad as in broke bad as in not function correctly i replaced them with a set i bought off ebay and car was fine
Old Dec 10, 2001 | 02:06 PM
ramair89's Avatar
Thanks! I found 8 matched 19 lb Bosch injectors from TPIS for around $300 I might look into getting those then.
MM2Robinson
Oct 1, 2017 09:16 AM
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
