airbox
Old Dec 11, 2001 | 09:11 PM
greasynuts's Avatar
airbox
What/where is the airbox, and what does it mean to "chop" it? How do I take the screens off of my MAF?
Old Dec 11, 2001 | 09:51 PM
Abubaca's Avatar
Since you mentioned MAF, I'm assuming you have a TPI. I wouldn't remove them. I DID remove them and I didn't notice anything, and although no harmful particals should make it past the filter, ya never know. Then comes the next point that the screens create TPI specific airflow that is important to the "tuning" of your TPI. I can't really argue this point, but do a search, you're sure to find it...guys, any other opinions?
As far as the airbox goes. Remove the dual snorkel inlets covering the filters. Remove the filters. What you see below the filters is all one piece. You should see screws around the outside of the "airbox". Remove the screws,( I think I recall it was about 8 or so, maybe less) the whole "airbox" will come out. From the top, see the squares that were covered by the filters? All those baffles can be cut out. You'll see screws in there and you can remove SOME of the baffles by removing them, but plenty more needs to be cut out. I did it and I thought it made a difference. Good luck.
Old Dec 11, 2001 | 10:09 PM
breathment's Avatar
chopping, or gutting the airbox is ur best mod, don't worry about the MAF, or if u do anything then only remove the screen on the engine side of it.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
http://www.geocities.com/david_angel_16
Old Dec 12, 2001 | 01:12 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
There is also a Tech Article on this.
Linson
Oct 24, 2025 02:00 PM
Z28z
Dec 23, 2001 01:56 PM
F0xBody50
Dec 13, 2001 11:57 PM
TRAXION
Aftermarket Product Review
Oct 24, 2000 05:23 PM
theformula
Oct 10, 2000 09:49 PM
