Questions about Runners
Old Jun 24, 2008 | 09:58 AM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
Since I am having to replace my injectors, I will have to remove the runners. While I'm at it, I might as well replace them with some better ones. If I replace them with ones that have a larger diameter, will I need to replace anything else they attach to? I assume you will have to get larger gaskets, but is there anything else? Also, is it possible to do a home paint job to the runners that lasts? If anyone has a pic of some installed painted runners, I'd like to see to get an idea of how it looks. Thanx in advance for any input.
Old Jun 24, 2008 | 10:18 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Re: Questions about Runners
just port match your upper and lower intake... i have mine painted but am going to repaint them... ill get pics up as soon as i can
Old Jun 24, 2008 | 10:23 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
ok cool. thanx
did you just use high temp paint?
Last edited by armygreen87; Jun 24, 2008 at 10:25 AM. Reason: Automerged Doublepost
Old Jun 24, 2008 | 10:36 AM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Get an Edelbrock Hi-Flo or TPiS big mouth manifold (they look exactly the same) and large tube runners from TPiS on AS&M (best price, they are the same) and have them polish them for you. This is the Edelbrock with polished (stock) runners. Its been in my car for a year now and is a really great manifold. Large tubes one day...$$$
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
when im port matching, does that mean i have to buy a new a new plenum?
gorgeous!!
Last edited by armygreen87; Jun 24, 2008 at 10:38 AM. Reason: Automerged Doublepost
Old Jun 24, 2008 | 10:56 AM
JDF-Z28's Avatar
Car: 1983 Z28
No...I've seen guys port match stock plenums to the large tube runners. There are a few sellers on ebay that will do it for you
Old Jun 24, 2008 | 11:10 AM
JDF-Z28's Avatar
Car: 1983 Z28
Here is an example of things that can be done. I saw this on ebay a few minutes ago.
[IMG][/IMG]
Old Jun 24, 2008 | 11:33 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
so having the holes blended to one like that is better for performance than just making the holes larger?
Old Jun 24, 2008 | 12:40 PM
JDF-Z28's Avatar
Car: 1983 Z28
They do that for siamesed large-tube runners. Supposed to flow better. SLP performance runners are siamesed I think. I will just enlarge the holes to match the larger TPiS tunners when I can afford to. Go look in the TGO tech articles for Siamesing Your TPI Intake. Also look for Suggested Mods for TPI engines they are under Miscellaneous Modifications.
Old Jun 25, 2008 | 08:51 PM
87350IROC's Avatar
Car: 87' IROC
Here are mine.
http://www.flickr.com/photos/perdoch...48375/sizes/l/
Painted with normal Nighthawk Black and High Temp Clear. Lasted 6 years so far. The key is thin coats.
They are AS&M runners.
Old Jun 26, 2008 | 11:48 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
ok cool. I'm not digging the black though, cuz of of the way they seem to blend in... I'd rather mine stand out more with a candy red or just have them polished like you have the plenum polished.
So which type of runner is better, siamesed or just having the larger runners?
Old Jun 26, 2008 | 12:54 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I modified my plenum and SLP runners, imitating what I saw on corvetteplenum.com. I got fairly good results, on my combo the motor held 300 rwhp to 5500 rpm. Also, check out the tech article (on the home page) titled "Siamesing your TPI Intake."
Bill
Old Jun 26, 2008 | 04:58 PM
87350IROC's Avatar
Car: 87' IROC
Honestly I would go with which ever runner looks better to you. The SLP style should be easier to polish. Why not just polish your stock ones? Unless you have a lot of other relavent mods on your LB9 I don't think you will notice a performance increase.
Old Jun 30, 2008 | 01:59 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
well i was planning to add mods in the future and figured that would be one needed mod along with others....i think i like the larger runners, i dont like how the SLP runners blend to look like one really wide runner...doesnt look as good to me. they cost more i think, but maybe one day I'll get em, prolly not anytime soon. thanks for all the input!
Old Jul 1, 2008 | 11:10 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
jdf-z28:Get an Edelbrock Hi-Flo or TPiS big mouth manifold (they look exactly the same) and large tube runners from TPiS on AS&M (best price, they are the same) and have them polish them for you. This is the Edelbrock with polished (stock) runners. Its been in my car for a year now and is a really great manifold. Large tubes one day...$$$
where could i get the tpis mig mouth manifold?
Old Jul 2, 2008 | 07:38 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
I have seen websites for them...i usually do a google search. u might even be able to find them on ebay
Old Jul 2, 2008 | 09:33 PM
87transGTA's Avatar
Car: 87 GTA
alright thanks
tazs2000
Jul 15, 2017 08:44 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
redmaroz
Aug 16, 2015 11:40 PM
