TPS volt readings
Old Dec 13, 2001 | 12:34 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
TPS volt readings
At idle it should read _______
At WOT it should read _______
Can someone fill in the blanks here for me?
Old Dec 13, 2001 | 12:42 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
.54(+/-.075) at idle
4.5(+/-.075) at WOT
Old Dec 13, 2001 | 12:44 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Did you read this info or is it from the top of your head?
Thanks either way!
Old Dec 13, 2001 | 01:19 PM
Desert86Roc's Avatar
Those are the correct numbers. Most of that kind of info can also be found in the Tech Article section.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
J-money
Jan 4, 2019 09:45 AM
TBRays98
Sep 6, 2015 05:05 PM
FormulasOnly
Sep 6, 2015 10:42 AM
scotrans am
Sep 5, 2015 04:26 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
