turning back odometers....
Old Dec 13, 2001 | 03:29 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm looking at getting a 145 speedo guage cluster. My car only has 68k miles on it, so will the numbers look F'd up if I get this speedo and turn back the odometer to what's on my car? I thought I once heard something about a silver stripe in the numbers or something if you turn them back. Please advise. Thanks
BTW, it's the '90-'92 setup that has the electric speedo if that matters.
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd B&M Ripper shifter, hopefully I can rob a bank or something and get more
www.geocities.com/irocnroll90
Old Dec 14, 2001 | 12:05 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by My90Iroc:
</font>
If a digitial dash the mileage is in a chip and you just can't roll it back
Old Dec 14, 2001 | 08:53 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The electronic speedo just means the signal to the speedo is electrical. All you will have to do is unscrew your original odometer and put it in the new speedo. The best way to do this is make sure the needle is ALL the way to zero. Do this by holding the swing arm behind the face plate. Then take not of where the needle was in relation to the grid (or something similar), and take the needle off. You can then swap the parts over. I did this with my bird, but the exact procedure is hazy since i did it ages ago. Email me if you want a more indepth answer.. i can also take a look at one of the spares i have for referance.
apo_bailon15
Mar 28, 2016 05:20 AM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
