New throttle body - high idle problem
Old Jul 2, 2008 | 08:52 PM
TPIMonteLS's Avatar
Transmission: Automatic!
I swapped on a 89-92 throttle body and cable to match the plenum and runners I put on after deleting the cold start. Now the car actually holds an idle on a cold start (yay) but the idle rises from about 1k rpm in park to about 1600 rpms. I tried to re-set the IAC but even with the IAC unplugged, same thing. I swapped on my adjustable TPS to the throttle body, I realize its off somewhat but could the TPS alone cause such a high idle? What other factors affect the idle? The injectors are 24lb ones, the engine is a mild 350 with the MAF setup. I do have an adjustable fuel pressure regulator I just put on and set the pressure to about 45psi, nothing too wild I don't think, but could that cause the high idle? Car did set a code, TPS voltage low and 02 after running for a minute or two.
Old Jul 2, 2008 | 10:54 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: New throttle body - high idle problem
throttle cables are different for 89-92 than 86-88. the throttle cable has to match the throttle body. is this a speed density motor or an maf
Old Jul 3, 2008 | 12:28 AM
TPIMonteLS's Avatar
Its a MAF setup, the cable was swapped at the same time as the throttle body, to match. Both are 89-92 peices. The idle won't back down even with the screw all the way in and pushing the throttle linkage by hand, so the cable isn't even a factor in the idle issue.
Old Jul 3, 2008 | 08:28 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
If the throttle body did come off a speed density setup did you make sure to put an adjustable tps sensor on it? You may have air coming in around the throttle body,,, spray starting fluid around the throttle body and intake while running to see if it surges? Also if the tps is the right one did you adjust it as out lined in the teck articles, timing issue if you pulled the dist?
Old Jul 3, 2008 | 07:38 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Can a non adjustable TPS/throttle body be used on a earlier MAF Throttle body engine or does the adjustable TPS need to be swapped over?
Old Jul 3, 2008 | 08:15 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
the maf needs an adjustable tps sensor, you will need to set the tps, iac and then time it.
Old Jul 3, 2008 | 09:10 PM
TPIMonteLS's Avatar
I didn't touch the dizzy, the car almost runs like it has a bad vacuum leak but I can't seem to find anything. I did swap over the adjustable TPS, having an issue trying to read the voltage though, so I know its off but I wouldn't think a TPS issue would cause it to run this far off.
Old Jul 3, 2008 | 11:18 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Sorry to take over your thread. Thanks wanab03ss, I will have to swap over my non adjustable TPS. I was just afraid of snapping a TPS bolt.
Old Jul 4, 2008 | 12:09 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the iac ports are diff in the throttle bodies
9th inj and non are a diff setup
Old Jul 4, 2008 | 12:38 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I didnt even think of that... Im not totally sure but I think you have to reprogram your ecu to eliminate the cold start injector.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
