TPI problems
Old Jul 10, 2008 | 11:29 PM
TRammy's Avatar
TPI problems
I have a 1986 firebird 305 and it has the folloing problems.
What I have done.
New plugs, cap rotor, wires. 45lb fuel whiel running or not.Checked timming chain.
Runs but misses some time it will run fine for a few seconds then start missing back fire and die or sounds like it drops cylinders.When it does sound like it is running on all cylinders it is running rich. I have to turn the distridutor advanced to get it to start.
Richard
Old Jul 10, 2008 | 11:45 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: TPI problems
Any error codes? If it is indeed running rich, you should be getting a code for that. Have you verified that all cylinders are getting spark? Hold old/how many miles on the injectors?
Old Jul 12, 2008 | 10:54 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: TPI problems
how did you check the timing chain
Old Jul 12, 2008 | 11:14 AM
TRammy's Avatar
Re: TPI problems
As for the timeing I checked the crank to distributoer relatinn and sack in chain.
I did do the jumper wire thing to retrive codes and the only one that came up was a # 12. The book said that means evey thing is OK.
Richard
Old Jul 13, 2008 | 06:46 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Re: TPI problems
Yes, code 12 is normal. It means no ignition pulses from the distributor, and its from when you turn the key forward before starting the car. I would recommend having the ignition module checked, Autozone can test it. It's located under the distributor cap, it's the part with all the wires going to it. I've seen them act up when they get hot, sort of like you're describing.
Old Jul 13, 2008 | 08:30 PM
TRammy's Avatar
Re: TPI problems
That sounds like a excilent Idea we only have a Knects here so i will ask them if they can do that. If not I ges I can buy a new one.
R/T
Old Jul 13, 2008 | 09:33 PM
TRammy's Avatar
Re: TPI problems
What does the spark controler module do?
Old Jul 13, 2008 | 09:59 PM
TRammy's Avatar
Re: TPI problems
Anyone got the replacement part# for the IGN contol Modual?
I looked on Ebay and can not find any with 5 small pins and two large ones for this year?
Old Jul 14, 2008 | 01:45 PM
TRammy's Avatar
Re: TPI problems
I just installed a new IGN Modual and it runs fine, I want to say a BIG THANKS to all that helped me on the delima.
Richard
Old Jul 14, 2008 | 03:22 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Re: TPI problems
Glad to hear that fixed it. Sort of late now, but the ignition module is what controls the timing advance. The ECM tells the ignition module how much advance it wants, and the ignition module makes it happen. Sort of the electronic equivalent of the vacuum advance on an old style distributor.
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
