Ignition gurus please help
Old Jul 22, 2008 | 07:12 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I can't seem to find any aftermarket ignition control module for my 89 firechicken, with the L98. I called autozone and they mentioned that in their performance section, they have one made by accel that might work. Has anyone tried this one? Did it last for a decent amount of time?
Old Jul 22, 2008 | 11:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Ignition gurus please help
Accel isn't known for their quality.
Old Jul 23, 2008 | 06:37 PM
all4u's Avatar
Car: Firechicken
Is it my only option cause I can't seem to find much of anything else and if it works, why not give it a shot. The problem is, I don't work for autozone anymore so I can't see what's up with parts without a part number. Is there another company that makes a module that would work?
Old Jul 23, 2008 | 09:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It might work for a while.
Any particular reason you want an aftermarket one?
Old Jul 24, 2008 | 07:20 AM
all4u's Avatar
Car: Firechicken
The stock one doesn't last as long as I expected. I need one every two months. Maybe I should stop shopping at carquest!
Old Jul 24, 2008 | 07:55 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
I would go with a MSD M6AL if I were you. I am running one now and everythig is flawless.
Old Jul 24, 2008 | 10:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're installing it correctly, with silicone grease on the heat-sink?
Old Jul 24, 2008 | 11:04 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
... you sure your looking hard enough?
Old Jul 24, 2008 | 07:15 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I find it hard to believe that you are getting a stock AC Delco control module from Carquest and thats your problem.Every aftermarket one that I've used has burned out faster than the AC Delcos and I've owned TPI thirdgens for 22 yrs.Try ordering one from rockauto.com and somewhere on this board is a discount code that you can use.
Old Jul 24, 2008 | 07:19 PM
Have to agree there, and the same goes with spark plugs. Went with so many different variations of both throughout the years, and in the end, I now find myself preferring AC Delco over them all....
Old Jul 24, 2008 | 07:22 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
AC Delco all the way when it's ignition (besides wires) related.
Old Jul 24, 2008 | 11:54 PM
all4u's Avatar
Car: Firechicken
Thanks yet again guys, I'll look into the flamethrower module and I do use AC delco rapidfires. It's not that they last the longest, which they do, but because they take n2o so well! I always wondered what the difference is between rapidfire 1's and 2's. Does anyone know?
Old Jul 25, 2008 | 06:12 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I've used the Flame Thrower and it burned out pretty fast.Stick with stock AC Delco
Old Jul 25, 2008 | 08:50 AM
all4u's Avatar
Car: Firechicken
Darn it. I want to find something that will last. Oh well, guess the aftermarket sucks for this kind of stuff. I'll get an ac delco on monday.
Old Jul 25, 2008 | 03:28 PM
jeffrynelson's Avatar
Car: 89 formula 350
Does anyone know where the discount code can be found for rockauto? thanks
Old Jul 25, 2008 | 07:19 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
here it is only good to Sept 12th
1079343703067
Enter your code in the "How did you hear about us" line of the shopping cart.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
