anoying ticking that i cant find!
Subscribe
Jul 23, 2008 | 08:29 PM
its silent at start up,after about a minute tick,tick,tick! it gets louder with rpm. i thought it was lalve lash,its not. thought it was a header flange leak,its not. its only coming from the driver side. im getting CRAPPY gas milage and my throttle surges at 2,000rpm and up?
Reply 0
Jul 23, 2008 | 09:00 PM
Re: anoying ticking that i cant find!
Quote: its silent at start up,after about a minute tick,tick,tick! it gets louder with rpm. i thought it was lalve lash,its not. thought it was a header flange leak,its not. its only coming from the driver side. im getting CRAPPY gas milage and my throttle surges at 2,000rpm and up?
bet you have a noisy injector a bad one can sound like a lifter. to check pull the connector off 1 at a time see if the noise goes away.. it will run on 7 injectors
Reply 0
Jul 23, 2008 | 09:04 PM
ill give that a try. thanks
Reply 0
Jul 23, 2008 | 09:06 PM
The injectors on TPI cars always tick, but since you say crappy gas mileage and surges then it definitely sounds like bad injectors.
Reply 0
Jul 23, 2008 | 09:18 PM
i pulled one at a time, the niose is still there? i could feel them ticking when i put my fingers on the plugs. all the injectors ohm out good aswell? if it was a exhaust leak on the driver side(where the nois is coming from) would that thorw the o2 sencor off being its on the same side?
Reply 0
Jul 23, 2008 | 09:31 PM
Like I said, they always tick. And just because the all ohm out ok, doesn't mean they are. It could still be a leaky injector causing the problems.
Reply 0
Jul 23, 2008 | 09:43 PM
bad injector very well may be? but thats not the tick im trying to track down.
Reply 0
Jul 23, 2008 | 09:49 PM
im going with worn piston pin.
have you ran that motor hard past 6000 a lot?
Reply 0
Jul 23, 2008 | 09:53 PM
6000 i wish.she wont go past 4500 . its not a wrist pin
Reply 0
Subscribe
