injctors sitting awhile,, need attention before install?
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I just bought a flow matched set (by cruzin performance) of #19 injectors, bosch stockers, from a board member. theve been sitting for almost a year now, after he put 5k miles on em. I was told they were only taken off so he could upgrade to a higher # injector. Is there anything I should run through em to clean out any dust or old fuel residue that may be in there before I install them?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: injctors sitting awhile,, need attention before install?
Carb cleaner and make sure you bench test them before installation.
Car: 87 GTA
Engine: 385 sbc
for ohms? If not how would I bench test flow?
Car: 1985 Iroc Z-28
I will be taking my intake apart in the next few weeks as I need to fix a coolant leak. Can you send a PM my way as well or post info here? If there is something I can do other than just an Ohm test to determine the status of my injectors, I would like to do it.
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
You don't have to worry about them.They were all wrapped and left in the box that I shipped them in.They were never left in the open and they were cleaned before they were put away
