Temp Sensors switched
Old Aug 9, 2008 | 06:01 PM
norcalace's Avatar
Are the pigtail connections to the coolant temp sensor and manifold air temp sensor the same?
Are the sensors the same?
What condition/s would it cause if they were switched with eash other?
Still trying to sort out a flooding condition.
Old Aug 10, 2008 | 06:56 AM
Damon's Avatar
Re: Temp Sensors switched
The sensors are not the same. The CTS is waterproof on the business end, the MAT sensor isn't, and I doubt they are calibrated the same. The plugs on them...... yeah, they could be the same plug. They certainly look very very similar where the plugs go on.
Old Aug 10, 2008 | 07:19 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
yep same weatherpak
Old Aug 10, 2008 | 10:53 AM
norcalace's Avatar
Kragen lists different part numbers for the CTS and inlet air temp sensors. Standard Motor Products list the same part number for both.
Autozone lists the same part number for both.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Bstrang6
Sep 8, 2015 04:29 PM
soarestransam
Aug 24, 2015 08:15 AM
