CAM help!
Old Aug 11, 2008 | 10:41 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
CAM help!
Ok I need help picking out a cam. I have never done this before. I have never done the cam usually just bolt-on's. My car has a 1996 vortec 350, scoogy and dickins intake,port plenum and ported SLP runners. I just ordered headman longtubes and a x pipe. what cam should I go with. valves and springs?
Old Aug 11, 2008 | 11:32 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: CAM help!
Here is what I used on a 355 vortec:
Comp Cams Extreme Energy Camshaft P/N 08-502-8
Crane Valve Spring Retainer Kit – P/N 10309-1
This setup can be run without modification to the stock vortec heads since the spring/retainer kit will give you clearance for the added lift.
This is also about the largest cam I would run with a stock torque convertor.
PS. Be ready to do some tuning.
Old Aug 11, 2008 | 11:45 PM
Axle/Gears: G92
Re: CAM help!
what do you mean tuning? can you tune the stock unit or do you have to buy a chip or get it reprogramed?
Old Aug 12, 2008 | 08:16 AM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: CAM help!
If you change the cam you will definitely require tuning (re-programming) of the spark and VE tables of the ecu. If you do not, it will run like crap. Mail order chips seldom work out well. It is best to buy the equipment to burn proms and do it yourself. Check out the DIY prom board. Lots of info there.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
