Edelbrock lower intake...where to mount the coil
Old Aug 15, 2008 | 07:34 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
On the stock intake the coil would have been mounted on the passenger side of the distributor. With the Edelbrock one that someone put on this car, there is no mounting for it so they drilled holes and mounted it to the firewall. Its ugly and i want to mount it neater than that. Any ideas? Does Edelbrock make a adaptor bracket or something?
Old Aug 15, 2008 | 09:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Edelbrock lower intake...where to mount the coil
The stock bracket mounts to the intake manifold using the rear two bolts, and it should fit on the Edelbrock intake too. How come yours doesnt?
Old Aug 15, 2008 | 06:09 PM
subroc's Avatar
Engine: 355 TPI
Are you saying the rear two bolts of the intake manifold? I thought for sure that there were separate holes on the original manifold specifically for the coil. Anyone got a good pic of how it is supposed to look? I have nothing to go on right now.
Old Aug 16, 2008 | 12:10 AM
Kevin91Z's Avatar
Yes, the rear two passenger side bolts of the intake manifold. The stock bracket mounts on those bolts. Sorry I dont have a pic.
Old Aug 16, 2008 | 07:18 AM
subroc's Avatar
Engine: 355 TPI
Hmmm ok. I wonder why the previous owner didnt put it back where its supposed to go. Oh well. Ill look into moving it. Not a fan of it hanging from the firewall.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
fasteddi
Sep 2, 2015 10:29 AM
TA8487
Aug 11, 2015 09:02 PM
