My last AIR DAM QUESTION
Old Aug 23, 2008 | 05:35 PM
IROCthings's Avatar
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
yeah ok so i bought a new air dam/deflector which ever you prefer. Anyways i bought a new one from GM and it did not include the clips screws whatever it uses. anyways i'm gonna have to ghetto fab mine on there so can anyone please show me how it is supposed to go on there. pictures of theirs or any would help.
Old Aug 23, 2008 | 05:47 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: My last AIR DAM QUESTION
I believe they use this kind of clip, which you should be able to get at Autozone:
Old Aug 23, 2008 | 05:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unsure if you mean the front ground effects or the air damn, which is located beneath the car. The latter is attached with four or five bolts, the ground effects with a weird-looking clip and bolt. Hit the bone yards for what you need--no need to rig anything and you can see how it all goes together.
JamesC
Old Aug 23, 2008 | 06:08 PM
IROCthings's Avatar
Axle/Gears: 3:73
JamesC
i'm talking about the air dam and i have already tried that. apparently thats a big problem for a lot of camaro owners. cause absoloutly 100 percent of the camaros i looked at were missing their air dam.
Old Aug 23, 2008 | 06:27 PM
JamesC's Avatar
They may have been missing the air damn (it's plastic after all), but I suggest the bolts were still in place.
JamesC
Old Aug 23, 2008 | 06:52 PM
IROCthings's Avatar
Axle/Gears: 3:73
JamesC
either way i'd still like a picture a layout something.
sorry this is my first F body.
Old Aug 23, 2008 | 07:08 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Post a pic of the new part you're replacing.
Old Aug 23, 2008 | 07:43 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
it just bolts to the bottom of the core support . the bolt holes rust out causing the dam to fall off on some cars and others get knocked off from bottoming out .
you can see the holes just by looking at the bottom of the core support , i dont know the exact size of the bolts . if you cannot get any to thread they may be rusted away , gust use a bolt / nut / washer combo that fits in the hole .
Old Aug 24, 2008 | 12:37 AM
IROCthings's Avatar
Axle/Gears: 3:73
thats what my original idea was, but i wanted to get an idea of what kind of supports GM uses cause i know if i just put some bolts in it at the top with nothing as a horizontal it'd probably bust off first time i bottom out. which we all know will happen.
Old Aug 24, 2008 | 07:20 AM
JamesC's Avatar
No supports.
JamesC
Old Aug 25, 2008 | 07:30 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Just get some nuts and bolts that hold it on. There is no way of attaching it except for the bolts along the top. I scrape a lot out around where I am and mine is still there. Its probably better that they have some flex in them.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
wruiz
Aug 13, 2015 09:07 PM
