fuel injectors installation height
Old Aug 27, 2008 | 10:10 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Has anybody had any experience with these fuel injectors from FIC on their 305 TPI http://fuelinjectorconnection.com/sh...d&productId=60
I am mainly concerned if they have the stock installation height and also how the car runs with them. I did a search and could not find anything about them. My car is at the shop and may need new fuel injectors. These are at a great price. I now that FIC cells modified bosch stile III three injectors for the L98, but this would require chip burning in order to make them work properly on my car. I currently don't have the money to do both the fuel injector replacement and the chip burning. Any suggestions would be greatly appreciated.
Thanks in advance.
Old Aug 27, 2008 | 01:28 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: fuel injectors installation height
Call that company, and talk to them. They claim that those injectors are for cars & trucks with TPI. Have them measure from center o-ring to center o-ring. Factory TPI injectors are 68mm (2.68") from center o-ring to center o-ring.
And, if you have a 305, then you want the 19#/hr injectors that you found. These should be flow rated at 43.5 psi.
Old Aug 27, 2008 | 02:14 PM
Saculia's Avatar
Engine: 305TPI
Thanks for the tip. I will give them a call.
Old Aug 27, 2008 | 04:31 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Ive got the Bosch III 22lbs modified on my car, they cost $169,95 and they got 3 years warranty and are flowmatched. Never got any better injectors then those (ive tested, Accel, Ford, Multec) and these got the best response.
I would buy the 22lbs Bosch III (modified, same install height as stock ones) anyday from Jon at FIC.
If you go with 22lbs on a 305 you need to adjust the prom (injector constant to the right value 22.02) or lower youre fuelpressure.
Call Jon up and talk to him about this, he will help you out.
Old Aug 27, 2008 | 05:23 PM
Saculia's Avatar
Engine: 305TPI
I spoke to Jon. He has the same exact injectors that are 19lbs and are the same price. You just need to specify that they are for LB9. The modified 19lbs Bosch III injectors are the ones I will get. Thanks a lot for your reply.
Old Aug 27, 2008 | 06:42 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
the o ring to o ring leanth is not the issue. its how the injector fits in the manifold and how high the top o ring goes into the rail. his sit up 1/4 inch due to the modified base. the 19lb bosch are white i believe. Anyway you look at it its a good deal. 3 yr warr.
Old Aug 27, 2008 | 10:22 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Those are bosch design II injectors, I'm running them on my car, in 19#. I got mine off ebay for $65 though, they had been cleaned and came with new o-rings. I had no fitment issues, and did not have to modify anything. They are about 1/8" shorter than the stock injectors though, you need to use the clips where they mount to the fuel rail. Otherwise, they will slip too far up into the fuel rail, and not go into the intake far enough. I also used GM size o-rings (which came in my fel-pro TPI gasket kit) on the injector bottoms, where they seal to the intake.
The car runs excellent with them and idles smoothly, although they cause a slight rich condition at WOT. This can be fixed with a tune, I just haven't got around to it yet.
Here's how they look:
Old Aug 27, 2008 | 10:55 PM
Saculia's Avatar
Engine: 305TPI
Thanks for the reply. This is some good info. Can you tell me where it is that you get the clips from? Did you use the clips from the stock injectors? Also, why did you use the GM o-rings? What are the problems with the o-rings that come with the injectors?
Thanks in advance.
Old Aug 28, 2008 | 12:42 AM
Theking's Avatar
Car: 1989 IROC-Z
You can reuse the C clips from the stock injectors.
The O-rings that comes with the Ford/Bosch II injectors are little smaller then GM stock ones, So they CAN cause a leak. Tpiparts sells 16 new GM O-rings for 21 dollars.. I bought them when I tested the Ford injectors, now im running Bosch III 22 lbs wich is much better, they are flowrated at 43.5 PSI instead of 39.15PSI as the Ford/bosch II ones..
heres how mine injectors looks like Bosch III is in the car now.:
installed:
Old Aug 28, 2008 | 05:01 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
installed:
the most important thing is the Bosch 3 are e10 compliant. Bosch 2 are not meaning they are suseptable to rust from the waqter content in the ethonol. This swap is a major PIA so why do it again. The ebay 65. look ok but they are not flow matched and probably don't have viton o rings. the cheep Buna rings can leak and burn your car up. Get the Bosch 3.
Old Aug 28, 2008 | 05:26 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The Ford/Bosch II injector, looks similar to the Ford/Denso in shape, but have 4 holes in the spray head, like the Bosch III.
The Ford/Bosch II is a disc design, not a pintle as the older Bosch type I.
The Ford/Bosch type II/III are rated from 20 psi to 60 psi working fuel pressure range, per the factory spec sheet.
The Bosch type III are the newest so are the best designed.
Old Aug 29, 2008 | 05:29 PM
the blur's Avatar
I too find the new injectors are not linear like the old multiteks.
they are either lean on the top end, or rich, or something different across the RPM range. I tried the new accels. 19 and 21lb.
also, check out this thread on the CF.
http://forums.corvetteforum.com/show...post1566899217
many guys seem to run rich after new injectors....
Old Aug 30, 2008 | 07:50 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Guys I to just bought the Design III for my iroc. I am very new to this so I have a question..I read to install the injectors into the intake manifold first then into the rail...Is that the way you guys do it with the design III..thxs!!
Old Aug 30, 2008 | 10:26 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
If you use the clips, its is rail first.
Old Aug 30, 2008 | 03:10 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
ny87iroc you have to put them in the intake first, you dont use the clips off the old injectors,you have to put them in the intake ,push them in until both o-rings are in all the way. then you carefully put them in the fuel rail, then push the rail down until you can put the 4 bolts in it .tighten the bolts down a little at a time until tight.jimmy
Old Aug 30, 2008 | 06:15 PM
NY87Iroc's Avatar
Ok, Thanks ALOT!!!!!
1992rs/ss
Jan 31, 2025 05:10 PM
bryan623
Mar 22, 2021 06:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
