Seeking opinions.
Old Sep 10, 2008 | 10:36 PM
NicksToyTA's Avatar
Car: 89 Trans Am... 92 25th RS
Engine: TPI 350 .03 over ported lower&bowls
Transmission: 700R
Axle/Gears: 2:73
Seeking opinions.
Hey folks. I have been running the fresh motor all summer its silky and strong. Recently i have noticed idle problems here and there, also luke warm hard starting. Investigation showed two injectors with very low resistance. I replaced all the injectors when i built the thing with obviously poor quality units as this is the second problem i have had with them. They are still warranted but i do not want to go through this project again needlessly. What injectors seem to be on the higher side of reliability?
Old Sep 11, 2008 | 10:04 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Seeking opinions.
If you do a quick search, most people like ford injectors. I use them and have had no problems.
Old Sep 11, 2008 | 10:19 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
LS1 injectors and never look back.
Old Sep 12, 2008 | 12:02 AM
NicksToyTA's Avatar
Transmission: 700R
Axle/Gears: 2:73
I did a search. Some people do like ford injectors, but a search on such a matter brings endless results. Its why I was seeking opinions. Thanks for yours, It seems a good bet. Has to beat the hell outa what I have going on at the moment...
Old Sep 12, 2008 | 07:53 AM
No problem. After my factory injectors went bad, I used Accel ones for a while... they only lasted about a year before they began failing! My advice is to stay away from Accel. Just my 2 cents.
Hope this helps!
Old Sep 12, 2008 | 09:52 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
What kind of injectors, did you have and what kind, do you have now?
Just wondering, so not to travel your unfortunate path.
I run the ford design II
Old Sep 14, 2008 | 04:32 PM
NicksToyTA's Avatar
Transmission: 700R
Axle/Gears: 2:73
Well....... I let one of my suppliers talk me into trying his remans. You see how it turned out he reimbursed me but the labor is a fall as well as a PITA. The company is Uremco........ I wouldn't recommend it.
Old Sep 14, 2008 | 07:31 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Take a look at these videos http://www.youtube.com/user/rbanner100.
1992Z28!
Nov 19, 2015 07:33 AM
HikoriYami
Sep 21, 2015 07:11 PM
WhteRbt
Sep 21, 2015 09:48 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
Twilightoptics
Oct 20, 2000 01:11 AM
