91 305 TPI reliability
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
sorry for a newb question, but its new to me.
I looking at maybe picking up a 1991 TA with a 305 tpi for a second DD/future project. How reliable is the motor? are there any issues that i need to know about? it has 82k on it and its all stock.
And what fuel mileage should i expect?
thanks
Phil
thanks
Phil
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: 91 305 TPI reliability
If your sure it has only 83k, and you do all the basic tune up stuff I`m sure you already know to do.It should be a pretty good car.Just being a older used car you never really know.My opinion and experience is expect to spend money and have to fix stuff.I drive 89 k1500 4x4 4.3 V6 and my Iroc.Two older chevys.Besides basic tune up stuff all I`ve HAD to replace is the transmission in both.Everything else could have been done without.I`ve also had 2 305 tpi cars and the engines have held up fine.My ex brother-in-law still drives my old T/A I bought it in 98 with 55k sold it in 00 or so with 125k.MPG`s...mine got a combined city/highway 20-22 mpg.Never really drove straight highway.However I`m getting a combined 19-22 in my current 350,and I have a HEAVY foot.If the price is right I`d go for it.A Chevy will run bad longer than most cars will run at all.
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
i second shadygrady, the sbc is almost indestructible with basic maintenance. tpi is very good too, very reliable thats why i am converting my car from carb to tpi.
Guest
Posts: n/a
You're doing almost exactly what I did some years ago. Its really going to depend on the past life of that motor. If it was reasonably maintained it should be fine. I can only suggest one thing, its a lot easier to replace valve stem seals with the engine sitting on a stand so you might consider doing that before you install it. I should have, and now one of these days I get to do it in the car. Replace any obviously leaking seals while you're at it.
Car: 86 Trans Am
i passed on it, has a little too much rust on the underside
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Yeah,I forgot about that.Not something you really have to worry about here.I cant imagine having to worry about adding rust restoration to my car/truck.That would prolly put restoration out of the ballpark for me.
Guest
Posts: n/a
i have one it supposed to have a 350 tpi out of vette but i think its got the 305 and i have put that car though hell and no problems yet 167,800 miles on it. i love these cars first one to so any mod info would be nice thanks and hope you get the car
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Read the tech articles on the main page and just search and read threads.I know a lot more than I knew when I got on here(which was almost nothing).There is a ton of info on here and probably any question you have has ben asked before.Also check out the FAQ on the main page.Welcome to TGO.
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
305, 350, 3rd, 89, 91, body, bottles, camaro, dangerous, gen, plastic, realiability, reliability, reliabilty, reliablility, tpi
