Chip Programming question.
Old Sep 28, 2008 | 11:00 AM
zosoruins's Avatar
I bought a 89 camaro with a 383 stroker TPI motor. The whole car seems to be heavily modified but the chip is stock.
I want to have TPIS make a custom one for me but i dont have the information about my camshaft or heads. I have emailed TPIS asking what to do and they have not responded. Is there a way to find out my cam and head specs short of pulling them out of the motor?
I have also tried to contact the cars previous owner but he has been less than helpful.
Anyone have a suggestion?
Old Sep 28, 2008 | 06:50 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: Chip Programming question.
I don't think that there's anyway to know what Cam you have without measuring the lift @ the rocker/lifter and doing a degree wheel measurement to find out the opening and closing degees of intake and exhaust. It can be complicated if you've never done it before....
Take the valve covers off the heads and see if they're stock or aftermarket.....Cast steel or Aluminum? what #'s do they have cast by the rocker studs...?
Maybe this thing isn't even a 383......
Old Sep 28, 2008 | 07:31 PM
zosoruins's Avatar
Thanks for the response. Far as i can tell they are aluminum heads. I will definitely pull the valve covers and look for some kind of ID #.
Any chance you want to explain to me how to do a degree wheel measurement?
Old Sep 29, 2008 | 12:24 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
http://www.cranecams.com/pdf/803.pdf
That should do it.......
It will let you know how much lift you have, (check intake and exhaust lobes) and will tell you the duration and opening and closing times of your valves.....
You still won't know what displacement you have unless you open it up and check bore X stroke
Old Sep 30, 2008 | 02:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
How well does the car run with such a wild combo and a stock chip? I'm guessing not that well. My 350 with an LT4 HOT cam would run so rich at idle it would burn my eyes. It was at that point I was forced to learn how to do my own custom chip.
Not to knock TPIS, but they are really proud of their work and charge accordingly. Unless they're in your backyard and are willing to spend the time with your car to tune it in properly, I wouldnt get one of their expensive chips. There are several other places around the country that can do a similar job for less money. Ed Wright at http://www.fastchip.com/ comes to mind.
Old Sep 30, 2008 | 07:16 PM
zosoruins's Avatar
It idles pretty rough and it also runs extremely rich. Still hits 12.5 in the quarter though. Hope a chip can help me improve on that
Old Oct 1, 2008 | 06:22 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Maybe it is a 383......... 12.5 is a good time in the 1/4 mile.
Have you found out what kind of heads are on it yet??? Brand, Size....
Mine was running super lean with 24lbs injectors and a "ADS superchip"
Old Oct 1, 2008 | 07:13 PM
zosoruins's Avatar
I am not positive but i believe they are Edelbrock RPM's. 70cc chambers. I do have 24 lb injectors. I havent had time to even think about the cam yet.
Old Oct 1, 2008 | 09:07 PM
Chevhead89's Avatar
see if its an externally balanced harmonic on the front. if it is then its a 383...
Old Oct 1, 2008 | 10:52 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
"Eagle" makes internally balanced rotating assemblies for 383's so I don't think that you could go by the harmonic balancer.
http://store.summitracing.com/partde...0&autoview=sku
etc............
either way, it makes no difference. Looks like you'll have to start datalogging that camaro and tuning your own chip. www.moates.net has equipment that lets you see and tune in realtime and download it into a peice of hardware that stays in your car.
http://www.moates.net/product_info.p...products_id=54
That's what I'm gonna do.....
Old Oct 2, 2008 | 09:22 AM
zosoruins's Avatar
Thanks for the info GTA!
THE APU1 looks great. I just ordered it.
Old Oct 2, 2008 | 02:48 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Great mang!
Tell me what it's like when you start using it.......... it's cold up here (3 weeks till snow) and the car is put away already.... rather than start something that I can't finish.
I'm gonna get mine in the spring along with bigger injectors...
Old Oct 16, 2008 | 07:22 PM
zosoruins's Avatar
Just got my stuff from Moates and i am admittedly out of my depth. It could take a while before i am able to use this thing.
Old Oct 17, 2008 | 12:26 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Obviously check out the prom page here and moates has stuff on his website, but I'm like you and don't even know where to start (that's why I haven't yet........... but really need too )
I'll send a couple of sites when I get home that I thought were good references. Whether it helps you out or not.........
Old Oct 18, 2008 | 11:41 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
These are a couple that I had found that give you a starting point or just something to read before you get started.
The second article is a nice to know page, but the first page gives you definitions to all (maybe not quite) the abbreviations used when it comes to programing. And the writer gives you an idea about where to start and what values to change and why..... From idle to cruise to WOT
http://www.diy-efi.org/gmecm/papers/tunetip.html
http://www.grapeaperacing.com/GrapeA...uelsystems.pdf
There is a ton of info on the DYI PROM & DFI / ECM pages as well..... and I've found that there are alot of people willing to help on ThirdGen.org.
Good luck!!!!
Old Oct 21, 2008 | 02:19 PM
zosoruins's Avatar
Really appreciate the help. Those sites were very helpful.
Old Oct 23, 2008 | 08:38 AM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
is the chip the same as a tune?
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
ULTM8Z
Oct 2, 2015 01:25 PM
