Hum from the rear of the car under braking...fuel pump?
Old Oct 6, 2008 | 12:32 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Hey all. I got have a hum coming from my cars rear end when i hit the brakes. It only occurs when there is less than half a tank of gas however. Im assuming this is the fuel pump? Should i look at getting it replaced? I already have the axle dropped to swap rear ends but am not really liking the idea of dropping another 100 or so on a new pump. What do you guys think? Normal or on its way out?
Old Oct 7, 2008 | 01:54 PM
subroc's Avatar
Engine: 355 TPI
Re: Hum from the rear of the car under braking...fuel pump?
No ones got anything?
Old Oct 9, 2008 | 10:39 PM
subroc's Avatar
Engine: 355 TPI
to the top again...still want to know what everyones opinion is.
Old Oct 9, 2008 | 10:44 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
just sitting there you should hear some higher pitched whining/humming which is normal for most fuel pumps. They do sell some that operate quieter... as for the condition only happening under a hard brake i'm not sure about that...
Old Oct 10, 2008 | 02:21 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Have you checked your brakes.......
Old Oct 10, 2008 | 03:46 PM
subroc's Avatar
Engine: 355 TPI
LOL yea i have. The drums are going anyways but its only when there is less than half a tank of gas so i thought that it was the fuel pump. I could be wrong though but the sound persists for a second or two even after im done braking.
Old Oct 10, 2008 | 10:27 PM
EGG's Avatar
EGG
Car: 88 Trans Am
I have kind of the same hum from the rear under braking, does yours continue for a couple of seconds after you've come to a stop?
I have a fairly noisy fuel pump, and drums in unknown condition.
Old Oct 10, 2008 | 10:44 PM
subroc's Avatar
Engine: 355 TPI
Yea mine continues for a couple of seconds after i come to a stop.
RazorN8
Jan 7, 2022 11:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
