i was told that the tps should be set at around .64 idle and 4.0 w/o. but if i set it at that, it runs like a dog. can someone help me out here?
Accorcing to the haynes manual it should be .54 to .56 idle
I did it at .54 and works fine
Originally Posted by 82taluver
Accorcing to the haynes manual it should be .54 to .56 idleI did it at .54 and works fine
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:27 Times in 23 Posts
Please read the tech article on this website about how to set your IAC and TPS sensors. By just setting it to .64 volts its probably either too far open or too far closed.
